Netflow on IOS XE - 4321 Router
ALIAOF_
Level 6
Level 6
Running the following on 4321
Cisco IOS XE Software, Version 03.13.04.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S4, RELEASE SOFTWARE (fc3)
Working on configuring netflow well flexible netflow on this router.  Here is my config that I was wondering if I can get reviewed.
Now unlike on the older routers I was not able to specify the following
flow timeout active 1
flow timeout inactive 15
flow timeout fast 64 threshold 30
Also I was reading the configuration guide of 4321 and it mentioned configuring Aggregation Cache however those commands are not available on 4321 so I am a bit confused there.
See my config below.  Thank you
### FLOW EXPORTERS ###
flow exporter SOLARWINDS-1
  destination 10.202.110.73
  transport udp 2055
  source loopback0
  export-protocol netflow-v9
  template data timeout 30
flow exporter SOLARWINDS-2
  destination 10.202.110.186
  source loopback0
### FLOW RECORD ###
flow record SOLARWINDS
  match ipv4 source address
  match ipv4 destination address
  match ipv4 protocol
  match ipv4 tos
  match transport source-port
  match transport destination-port
  collect routing next-hop address ipv4
  collect transport tcp flags
  collect counter bytes
  collect counter packets
  collect timestamp sys-uptime first
  collect timestamp sys-uptime last
### FLOW MONITOR ###
flow monitor SOLARWINDS
  record SOLARWINDS
Hello.
FNF is slightly different from legacy netflow and for IOS XE you should use FNF CLI.
Cahce timeouts goes to flow objects (like monitor).
Link -Flexible NetFlow Configuration Guide
