Network Browsing
shoebwk
HI, i have configured the router. Everything seems to work. i can ping from both end with ip address and DNS name. But i cannot see the list of computers in the network tree at both end, i.e neither at the H.O nor at the branch office.
Could you suggest me changes in the IOS so that i can browse the network of my head office.
I have windows 2003 domain environment and all the Branch computers are successfully connected to domain
==============H.O Router(RTR-A)===============
Current configuration : 1413 bytes
version 12.4
hostname RSC_PP_TR
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip domain name abc.com
ip name-server 10.104.16.140
interface FastEthernet0/0
description LAN CONNECTS TO PORT3 OF FG-300A
ip address 192.168.16.10 255.255.255.248
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
description CONNECTS TO tr-rtr S0/0/0
ip address 192.168.10.1 255.255.255.252
interface Serial0/0/1
no ip address
shutdown
clockrate 2000000
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.16.9
ip route 10.104.17.0 255.255.255.192 192.168.10.2
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit any
control-plane
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
login local
=========Branch router (RTR-B)===============
Current configuration : 1514 bytes
version 12.4
hostname tr-rtr
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
ip dhcp excluded-address 10.104.17.1 10.104.17.10
ip dhcp pool TR_Centre
network 10.104.17.0 255.255.255.192
dns-server 10.104.16.140
default-router 10.104.17.1
description LAN INTERFACE ON SWITCH
ip address 10.104.17.1 255.255.255.192
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
description CONNECTS TO HO_S0/0/0
ip address 192.168.10.2 255.255.255.252
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.1
ip route 10.104.16.0 255.255.255.0 192.168.10.1
ip dns server
ip http server
control-plane
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
SK
andrew.burns
Level 7
Level 7
This is a Microsoft issue and can't be resolved by any Cisco configuration. Search Microsoft's site using the query "Troubleshooting Browsing" and you'll find some pointers.
Andrew.
Anand Narayana
Level 6
Level 6
Hi SK,
the reason why you couldn't see the other computers running on the remote side is because they are not broadcasting the information to the computers in your end, basically listing the computers on the network neighborhood is happening through broadcast, since these broadcast cannot pass via router, thats the reason you couldn't see the list of computers on the remote end.
but when ur in the same network, you can the list of computers getting displayed in the nettwork neighborhood.
hope this helps.
rate this post if ur satisfied.
