network connectivity on PIX 515E
larryfocust
I am trying to recover a password on a PIX 515e. I set the interface address, gateway address, server address, and cannot ping the server, cannot see it on the network, etc. I am at a loss. I've never had this problem before.
mwall1
How many interfaces are there and which one are you plugged into? Can you ping anything from the PIX?
My 525 has 10 interfaces on it but I am only using interface 0 for the recovery. Once I have link to interface 0 then I issue the following commands:
monitor>interface 0
monitor>address 192.168.98.131
monitor>server 192.168.98.130
monitor>file test.bin
monitor>ping 192.168.98.130 (success)
monitor>tftp
The ping, for me at least, only worked from PIX to my tftp server which was directly attached to interface 0 on the PIX (crossover cable). I did receive 20 percent packet loss during the ping which was interesting but the tftp was very fast... I could not ping the PIX from my tftp server. It also only worked if I issued the commands while the link was active.
Hope this helps.
