Network Implementation using Cisco 2811
chrislgicale
Hi Guys,
Good day!
Previously /24 subnetting is suffice to our users, but moving forward to a bigger number of users I'm looking to extend our subnetting to /22 to accommodate the whole project site network. I'm detailing our estimated users, as well as available resources for your suggestion. Sorry not all are cisco devices.
*Head Office*
     /24 subnet
     100 users
     50 IP phones (Polycom)
     Cisco 2811 as gateway and serial going to project site
     Cisco WS-C2960S-24TS-L for data network
     CIsco WS-C2960S-24PS-L for voice network
     One DHCP/AD server
     One virtualization server
*Project Site*
     currently /24 --> will extend to /22
     350 - 400 users are expected
     100 IP phones (Polycom)
     Cisco 2811 as gateway and serial going to head office
     three project sites are connected thru fiber-optic
     Two DHCP/AD server (currently)
I'm focus more on project site since I'm the one handling and managing it, but has limited skills in implementation, and my first time to have this number of users and devices. One of my colleagues says, I have to add Cisco 4500g as my distribution and core switch while implementing VLANs.
I know with the help of members here, I can have some good to great solutions using my available devices.
Thank you in advance.
Chris
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Depending on you traffic flows, if there's no need for intra-site routing, the 2811 can route between VLANs hosted on the 2960Ss.  (If you need intra-site routing, the 2811 can do that too, but they likely would be a bottleneck.  [I'm also assuming the WAN link is small enough, the 2811s won't be a bottleneck for that.])
The 2960S, with later IOS versions, support limited static routing.  This could be used in conjunction with routing on the 2811s.
If you need LAN routing, with full routing support, you'll want to consider obtaining a L3 switch.  For a LAN as small as yours, you don't need core and distribution layers, collapsed core will be fine.  For a L3 switch, you might consider a 3xxx or 49xx switch.
Thanks Joseph.
