Network Mask as destination in route-filter ACL?
xianglingzj
Recently I found such kind of access list on my company's device
Switch>sh ip access-l 101
Extended IP access list 101
10 permit ip host 10.192.96.0 host 255.255.255.0 (1 match)
20 permit ip host 10.192.98.0 host 255.255.255.0 (1 match)
30 permit ip host 10.192.99.0 host 255.255.255.0 (1 match)
30 permit ip host 10.192.96.7 host 255.255.255.255 (1 match)
40 permit ip host 192.168.9.0 host 255.255.255.0
50 permit ip host 172.16.11.128 host 255.255.255.240 (1 match)
And this access list is used for route filtering.
Switch#sh run | b router eig
router eigrp 69
redistribute static route-map STATIC-TO-EIGRP
passive-interface default
no passive-interface Vlan104
no passive-interface Vlan106
network 10.192.0.0 0.0.255.255
network 192.168.168.0
no auto-summary
eigrp router-id 10.192.96.1
<Omitted>
Switch#sh route-map STATIC-TO-EIGRP
route-map STATIC-TO-EIGRP, permit, sequence 10
Match clauses:
ip address (access-lists): 101
Set clauses:
Policy routing matches: 0 packets, 0 bytes
route-map STATIC-TO-EIGRP, deny, sequence 20
Match clauses:
Set clauses:
From the "show ip route" command output it looks like this access list is functioning as the following standard access list
10 permit 10.192.96.0 0.0.0.255
20 permit 10.192.98.0 0.0.0.255
30 permit 10.192.99.0 0.0.0.255
30 permit host 10.192.96.7
40 permit 192.168.9.0 0.0.0.255
50 permit 172.16.11.128 0.0.0.15
Can anybody advise me
1) How does access list 101 functioning?
2) What's the pros and cons to use this method instead of standard access list or prefix list to filter routes?
Thanks!
network.king
Level 4
Level 4
The above access-list with not only matching the network but also the mask associated with a prefix . So the above ACL would allow advertisement of network if both the network and prefix length matches .
If u have 10.192.98.0/24 and 10.192.98.0/28 are there , this would advertise only the /24 and not /28 , but the ACL would advertise both.
In case of using the Prefix list , its just the flexibilty it gives to us in using the same.
Hope it helps
regards
vanesh k
