Network Objects & ACL's
DanielSheppard
Just wondering if anyone else is experiencing any oddness when using network objects with ACL's and their corresponding route-maps/etc
I have a network object which contains other network objects and when I used these in a route map to restrict NAT, it woudl use this network object as a 100% match.
I also noticed similar behaviour with other route maps and in the firewall itself(skipping the objects as if they were not a match and instead hitting the class-default deny all).
This is both on a Cisco 871 and 1811 with the 871 using 12.4(24)T4 and the 1811 using 15.1
fadlouni
Hi Daniel.
You'd get more visibility on your thread if you move it to the network infrastructure forums, and so more likely a chance to get an answer.
Fadi.
Thanks, I have went ahead and moved the thread as suggested to WAN, Routing and Switching.
