new C1111-4P router does not boot anymore
markus_penner
Hi Community,
I´ve a problem with a new delivered C1111-4p router.
I just wanted to downgrade the IOS-XE to an other version. The IOS-XE which was installed from the factory in the bootflash: was "c1100-universalk9_ias.16.12.05.SPA.bin". So have copied my IOS-XE version (c1100-universalk9_ias.16.06.07.SPA.bin) into the bootflash: and deleted the other one.
I was deleting the whole config an rebooted the router. And now I have got the problem, that the router is stopping the boot procedure at the point "Image validated".
It looks like this ->
Rom image verified correctly
System Bootstrap, Version 17.6.1, RELEASE SOFTWARE
Copyright (c) 1994-2021 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
C1111-4P platform with 4194304 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
Located pnp-tech-time
Unsupported package header version (-1347440721)
Located pnp-tech-discovery-summary
Unsupported package header version (542463043)
Located memleak.tcl
Unsupported package header version (540160049)
Located throughput_monitor_params
Located c1100-universalk9_ias.16.06.07.SPA.bin
Package header rev 3 structure detected
IsoSize = 319068160
Performing Integrity Check ...
Performing Signature Verification ...
RSA Signed RELEASE Image Signature Verification Successful
Image validated
Would be very very thankfull for help! Thanks!
Mark Elsen
         - FYIhttps://bst.cloudapps.cisco.com/bugsearch/bug/CSCvt13665
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks for your answer ....
but I do not have a problem with a ROMMON upgrade. My router has ROMMON version 17.6.1 and I have copied another IOS-XE version to the bootflash and now, the router does not boot anymore.
- From  initial post :     >...So have copied my IOS-XE version (c1100-universalk9_ias.16.06.07.SPA.bin)
   Since you effectively downgraded what happened probably is that this version is not compatible with the current ROMMON version.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
v.snijder
It is because you have the factory installed new ROMMON 17.6.1
Read this Field Notice :
https://www.cisco.com/c/en/us/support/docs/field-notices/723/fn72304.html
