01-11-2012 11:09 PM - edited 03-04-2019 02:52 PM
Can anyone tell me what´s the differende between 15.0(2)SG2 and 15.0(2)SG3 for Cat 4500. it´s brandnew but release notes doesn´t really show big differences (only one caveat solved).
thanks
01-20-2012 08:34 PM
Not much chabged indeed. Though other than this ceveat fixed there are some additional commands added and some behaviour changed. E.G.
diagnostic fpga soft-error recover aggressive
Hope this helps,
Nik
01-20-2012 08:46 PM
I just did some more search.
This rebuild was posted due to a Sup7E ceveat fix. K2/K5 images are nearly identical to 15.0(2)SG2.
Nik
01-24-2012 08:27 AM
Features wise: No difference in these two images
And the Filename you've mentioned is only compatible with Superviser modules till SUP-V. It's not valid for SUP-6 & SUP7
Check Feature Navigator tool, I used this for comparing these two images for any feature difference:
http://tools.cisco.com/ITDIT/CFN/jsp/compareImages.jsp
Hope it helps
Neeraj
02-02-2012 12:43 PM
thank you very much
