New to ASA's Need some advice on getting it to work
barryrosenhouse
Took a cisco ASA 5505 from another site and installed in a new site, changed the ip's on the 5505 inside and outside, but I dont know what to add to the headquarters 5515 to get vpn light on remote asa. Please help!!!!! We have an engineer at the remote site for a short period of time. I can provide a config if that helps.
2 Accepted Solutions
you mean the IPSec VPN modify after change the IN/OUT interface IP ??
If that what you ask then
change the NAT exemption <-since you change the IN subnet
change the ACL of IPSec <- since you change the IN subnet
change the IPSec Peer IP <- since you change the OUT
Not sure if this is resolved. If not here are some suggestions:
- on the ASAs at the new site there might be some route statements that need to be changed.
- on the ASAs at the new site it would be good to examine the config for any statements that reference the addressing of the subnet of the outside interface and the addressing of the inside interface.
- on the head end ASA there might be some route statements that need to be changed (check especially for any references for the subnets of the previous remote ASA).
- on the head end ASA there might be some statements in vpn config that need to be changed (check especially for any references for the subnets of the previous remote ASA).
- on the head end ASA it would be good to examine the config for any statements that reference the addressing of the subnet of the outside interface and the addressing of the inside interface of the previous remote site.
Rick
7 Replies 7
Ok thx
I am glad that our suggestions have been helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
if you are looking to have site-to-site vpn between HO and remote site, use below guide by replacing your required IP addresses and networks.
https://packetlife.net/blog/2011/jul/11/lan-lan-vpn-asa-5505/
Good luck
KB
I will def check this out - thx - will let you know
Rick
barryrosenhouse
Thanks much
