Newbie: Activating NAT
an_ho
Hi everyone,
I am very new to Cisco Routing, so please don't mind if this is a trivial question:
On my router, the interface gig0/0/1 is the WAN interface and gets an IP address via DHCP from my ISP. I have created a DHCP pool (192.168.1.0/24 with 192.168.1.1 as default gateway) and assigned 192.168.1.1 to gig0/1/0. Now, the initial configuration wizard on IOS XE asked my to activate NAT on the WAN interface which I did - but if I do this, I do not get an IP address from my ISP (works fine if NAT is deactivated). Since I simply want to enable internet access to all clients in the 192.168.1.0/24 subnet, how can I configure NAT for them?
Any help is greatly appreciated!!!
Andrew
you can add an access list to the WAN interface as configured below:
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 4.4.4.2
interface GigabitEthernet0/0/1
description WAN Interface
ip address dhcp
--> ip access-group DENY_SSH_HTTP_HTTPS in
ip nat outside
interface GigabitEthernet0/1/0
description LAN Interface
ip nat inside
ip nat inside source list 1 interface GigabitEthernet0/0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/1 dhcp
access-list 1 permit 192.168.1.0 0.0.0.255
--> ip access-list extended DENY_SSH_HTTP_HTTPS
--> deny tcp any host WAN_IP eq 22
--> deny tcp any host WAN_IP eq 80
--> deny tcp any host WAN_IP eq 443
--> permit ip any any
7 Replies 7
not sure what exactly the configuration wizzard actually adds to the config, but if you can, try and get to the command line (CLI) and make sure your configuration looks like below:
ip dhcp pool LAN
ip address dhcp
ip nat outside
ip nat inside
Thank you! That was really helpful!!!
However, I realized that ssh/http/https for configuration are accessible on the WAN interface from the outside world. How can I prevent that?
Andrew
ip dhcp pool LAN
ip address dhcp
ip nat outside
ip nat inside
Thanks again! Unfortunately, when I use "ip access-group" it gives me an "invalid input" error message. Also, my WAN IP is set via DHCP from the ISP...or is WAN_IP a dynamic placeholder?
Andrew
what router model do you have exactly ? You might be better off configuring a zone based firewall. Post the full config of your router (sh run) so I can fill in the bits and pieces...
I own a C1111X-8P with an ip base license. Do I need a specific license to activate ip access-groups?
To be honest, for a newby like myself, the Cisco licensing model is really (!) hard to understand. Is there a table somewhere that lists in detail what features are available with a specific license? For example, would it be possible to run snort IPS on this router (given the right license)?
Andrew
Hello
Regard your the nat without looking at the configuration it would be hard to see how your rtr is setup- however for a simple port address translation it shouldn’t be to hard to figure out if you can share this
As for you ssh/telnet access to the rtr another way would be to negate with a access-list appended to the vty lines using an access class as such no need to for the acl on the physical interface.
example:
access-list 1 permit 192.168.2.0 0.0.0.255
line vty 0-4
access-class 1 in
access-class 1 out
Kind Regards
Paul
