Nexus 7010 interface question
I was configuring SVIs into a non-default VDC and the following message appeared:
Non-routable VDC mode
Thw switch is configured with many trunks passsing traffic from all the vlans.
Output:
Interface Secondary VLAN(Type)                    Status Reason
Vlan1     --                                      down   VLAN is down
Vlan10    --                                      down   Non-routable VDC mode
Vlan15    --                                      down   Non-routable VDC mode
Vlan500   --                                      down   Non-routable VDC mode
Vlan604   --                                      down   Non-routable VDC mode
Vlan700   --                                      down   Non-routable VDC mode
Vlan701   --                                      down   VLAN is down
Vlan702   --                                      down   Non-routable VDC mode
Vlan703   --                                      down   Non-routable VDC mode
Vlan704   --                                      down   Non-routable VDC mode
In order to activate the interfaces it was necessary to apply the command "management"
interface Vlan10
  no shutdown
  management
  ip address A.B.C.D/24
And then....
Vlan1     --                                      up     --
Vlan10    --                                      up     --
It is necessary to apply this command all the time?
n7000-s1-dk9.5.2.1.bin
N7K-F132XP-15
Thanks for your help,
Alejandro Serrano
Oleksandr Nesterov
Alejandro, to run normally SVIs in your CDC - you need to add M1 card to it, because F1 cards are completely L2 cards and for L3 processes use resources of M1 modules. Otherwise routing won't work. And using keyword management will add route to management vrf which is used for management.
HTH,
Alex
Jerry Ye
The F1 is a L2 only linecard.
Do you want to use VLAN 10 for management traffic only? If yes, you can create a interface mgmt 0 and it will use the same mgmt interface on default VDC to send management traffic out.
HTH,
jerry
Oleksandr Nesterov
HTH,
Alex
Thank you very much for your support, I was thinking about the line card type but I wasn´t sure.
Alejandro.
