Nexus 7010 limited syntax
RRDLOCKDOWN
Our 7010 is on  BIOS: version 2.12.0, kickstart: version 8.2(3), system: version 8.2(3) and I'm planning to upgrade it to 8.2(5). For some reason, I don't seem to have the rest of the options available under "show install all" as I would like to test the upgrade process before doing it permanently. Below are the outputs.
I can do show incompatibility system bootflash:// just fine but...
n7k-prime# show install ?
all Output of the recent 'install all' operation
n7k-prime# show install all ? <<<< no impact syntax
failure-reason Show failure reason for the last install all
So I'm unable to do show install all impact kickstart bootflash://<image> system bootflash://<image>
Has anyone experienced the same? Appreciate your help.
pieterh
I suggest you need to issue the command: "show install all failure-reason"
to find the cause of the failure of an earlier install command.
