Nexus 7k ISSU Upgrade
Vinayaka Raman
Please check If I am missing something. Few questions on top of my mind.
  • 1. There is dedicated port called CMP-mgmt. Should I configure it and use during my upgrade like OOB mgmt?
  • 2. What is an EPLD image? Should I upgrade these also.
Regards Vinayak
Jerry Ye
Took a quick look, it looks fine.
1) you can use the CMP during upgrade.
2) EPLD image is the microcode for the line cards. It enables new features support for the hardwares. EPLD is not ISSU and it is discruptive (minimum downtime per module is ~15 min). If you can upgrade it, it will be great. If you cannot affort the outage, you can be leave it alone.
HTH,
jerry
