Nexus 7K VDC Interface Re-allocation - Proxy Layer 3 Routing
David Undernehr
I have a Cisco Nexus 7k with the following modules installed:
Mod  Ports  Module-Type                         Model              Status
1    0      Supervisor module-1X                N7K-SUP1           active *
2    0      Supervisor module-1X                N7K-SUP1           ha-standby
3    48     10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L     ok
6    32     1/10 Gbps Ethernet Module           N7K-F132XP-15      ok
9    48     1000 Mbps Optical Ethernet XL Modul N7K-M148GS-11L     ok
I want to migrate interfaces from my Core VDC to my Data Center VDC. However, when performing this task I will break Proxy Layer3 routing.
vdc_id: 1 vdc_name: CORE-02 interfaces:
        Ethernet3/33          Ethernet3/34          Ethernet3/35
        Ethernet3/36          Ethernet3/37          Ethernet3/38
        Ethernet3/39          Ethernet3/40          Ethernet3/41
        Ethernet3/42          Ethernet3/43          Ethernet3/44
        Ethernet3/45          Ethernet3/46          Ethernet3/47
        Ethernet3/48
        Ethernet6/1           Ethernet6/2           Ethernet6/3
        Ethernet6/4           Ethernet6/5           Ethernet6/6
        Ethernet6/7           Ethernet6/8           Ethernet6/9
        Ethernet6/10          Ethernet6/11          Ethernet6/12
        Ethernet6/13          Ethernet6/14          Ethernet6/15
        Ethernet6/16          Ethernet6/21          Ethernet6/22
        Ethernet6/23          Ethernet6/24          Ethernet6/25
        Ethernet6/26          Ethernet6/27          Ethernet6/28
        Ethernet6/29          Ethernet6/30          Ethernet6/31
        Ethernet6/32
vdc_id: 3 vdc_name: DC-02 interfaces:
        Ethernet3/1           Ethernet3/2           Ethernet3/3
        Ethernet3/4           Ethernet3/5           Ethernet3/6
        Ethernet3/7           Ethernet3/8           Ethernet3/9
        Ethernet3/10          Ethernet3/11          Ethernet3/12
        Ethernet3/13          Ethernet3/14          Ethernet3/15
        Ethernet3/16          Ethernet3/17          Ethernet3/18
        Ethernet3/19          Ethernet3/20          Ethernet3/21
        Ethernet3/22          Ethernet3/23          Ethernet3/24
        Ethernet3/25          Ethernet3/26          Ethernet3/27
        Ethernet3/28          Ethernet3/29          Ethernet3/30
        Ethernet3/31          Ethernet3/32
CORE-02# show hardware proxy layer-3 detail
Global Information:
        F1 Modules:     Count: 1         Slot: 6
        M1 Modules:     Count: 1         Slot: 3
        Replication Rebalance Mode:             Manual
        Number of proxy layer-3 forwarders:     2
        Number of proxy layer-3 replicators:     2
Forwarder Interfaces                     Status     Reason
Eth3/33-36                               up         SUCCESS
Eth3/37-48                               up         SUCCESS
Replicator Interfaces                    #Interface-Vlan   Interface-Vlan
Eth3/1-24                                2                 1,36
Eth3/25-48                               2                 40,75
Question: How do I perform what seems to be an easy task without an outage in my Core and what steps do I need to take?
David
David Undernehr
IEOC.com (Brian McGahan) answered my question first but I also found the Cisco documentation as well.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/unicast/configuration/guide/l3_overview.html#wp1127975
You must install one of the N7K-M series modules in the Cisco Nexus 7000 Series chassis to run Layer 3 routing with the N7K-F132-15 module. You must have interfaces from both the M Series and the N7K-F132-15 modules in the same VDC. (See the Cisco Nexus 7000 Series NX-OS Virtual Device Context Configuration Guide, Release 5.x,
for more information about VDCs.)
So in short, I can not migrate interfaces Eth3/25-48 out of VDC Core and place them into my DC VDC as this will remove all M Series (Layer 3) interfaces from my Core.
