Nexus-7k
Sandeepka
I want to know the port architecture of N7K-M132XP-12 in shared and dedicated mode.  Means in dedicated mode I get 10 gig on single interface while rest other ports in that group will be disable. In shared mode 10 gig will be shared between four ports. Now my question is, in shared mode is 2.5gig is dedicated to each four port, means if I have only single connectivity in shared mode among the group then will I get 10gig or just 2.5gig?
Roman Rodichev
Level 7
Level 7
You will get 10GIG. The bandwidth is shared between ports. If only one port is using it, it will get 10GIG.
