09-19-2022 08:17 AM
I am wondering if it is possible to bring up an MP-iBGP peering between two, directly connected N9k switches to exchange multi-vrf routing information. No MPLS, but direct P2P connection between them. To begin with, I can't see vpnv4 address family appearing nowhere.
The goal would be to eleminate several, per-vrf P2P peerings between the two.
Solved! Go to Solution.
09-19-2022 02:33 PM
Hi there!
If Im understanding what you are trying to do..The short answer is 'yes, you can.'
I have two Nexus 9000s connected via Eth1/1 peered over iBGP (RRs). Their sample configurations below:
Nexus-1# show run bgp
!Command: show running-config bgp
!Running configuration last done at: Mon Sep 19 21:20:42 2022
!Time: Mon Sep 19 21:27:39 2022
version 9.3(3) Bios:version 05.45
feature bgp
router bgp 65111
router-id 1.1.1.1
log-neighbor-changes
address-family ipv4 unicast
network 1.1.1.1/32
address-family vpnv4 unicast
neighbor 2.2.2.2
remote-as 65111
update-source loopback0
send-community
send-community extended
route-reflector-client
vrf BLUE
vrf RED
Nexus-1# show run int loo0
!Command: show running-config interface loopback0
!Time: Mon Sep 19 21:30:47 2022
interface loopback0
description BGP Router-ID
ip address 1.1.1.1/32
ip router ospf Support-Forum area 0.0.0.0
Nexus-1# show run int e1/1
!Command: show running-config interface Ethernet1/1
!Time: Mon Sep 19 21:30:49 2022
description To Nexus-2 iBGP
mtu 9216
no ip redirects
ip address 172.18.1.1/30
no ipv6 redirects
no shutdown
Nexus-2, who has a mock prefix in VRF RED and VRF BLUE respectively:
Nexus-2# show run bgp
!Running configuration last done at: Mon Sep 19 21:24:19 2022
!Time: Mon Sep 19 21:29:21 2022
feature bgp
router bgp 65111
router-id 2.2.2.2
network 2.2.2.2/32
neighbor 1.1.1.1
remote-as 65111
send-community
vrf BLUE
network 65.33.33.33/32
vrf RED
network 65.22.22.22/32
Nexus-2# show run int loo0-2
!Command: show running-config interface loopback0-2
!Time: Mon Sep 19 21:29:55 2022
interface loopback0
description BGP Router-Id Loo
ip address 2.2.2.2/32
interface loopback1
description VRF RED
vrf member RED
ip address 65.22.22.22/32
interface loopback2
description VRF BLUE
vrf member BLUE
ip address 65.33.33.33/32
Nexus-2# show run int e1/1
!Time: Mon Sep 19 21:30:16 2022
description To Nexus-1 iBGP
mtu 9216
no ip redirects
ip address 172.18.1.2/30
no ipv6 redirects
no shutdown
You can see that although only peered once, they are exchanging routes from VRF BLUE and RED, without an additional peering over those VRFs as well.
Nexus-1# show bgp vpnv4 unicast summary
BGP summary information for VRF default, address family VPNv4 Unicast
BGP router identifier 1.1.1.1, local AS number 65111
BGP table version is 12, VPNv4 Unicast config peers 1, capable peers 1
4 network entries and 4 paths using 720 bytes of memory
BGP attribute entries [2/336], BGP AS path entries [0/0]
BGP community entries [0/0], BGP clusterlist entries [0/0]
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
2.2.2.2 4 65111 62 48 12 0 0 00:30:35 2
BGP routing table information for VRF default, address family VPNv4 Unicast
BGP table version is 12, Local Router ID is 1.1.1.1
Status: s-suppressed, x-deleted, S-stale, d-dampened, h-history, *-valid, >-best
Path type: i-internal, e-external, c-confed, l-local, a-aggregate, r-redist, I-injected
Origin codes: i - IGP, e - EGP, ? - incomplete, | - multipath, & - backup, 2 - best2
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 65222:65222 (VRF RED)
*>i65.22.22.22/32 2.2.2.2 100 0 i
*>i65.33.33.33/32 2.2.2.2 100 0 i
Route Distinguisher: 65333:65333 (VRF BLUE)
P.S: Im guessing the MPLS features are not enabled in the Nexus switch you are trying to do this in yet and that is likely why you cannot see the vpnv4 AF anywhere yet.
Example -- Quick neighbor config and vpnv4 AF missing:
Nexus-2(config-router-af)# router bgp 65111
Nexus-2(config-router)# router-id 2.2.2.2
Nexus-2(config-router)# log-neighbor-changes
Nexus-2(config-router)# address-family ipv4 unicast
Nexus-2(config-router-af)# neighbor 1.1.1.1
Nexus-2(config-router-neighbor)# address-family ?
ipv4 Configure IPv4 address-family
ipv6 Configure IPv6 address-family
l2vpn Configure L2VPN address-family
link-state Configure link-state address-family
But if I enable the feature set for MPLS, then vpnv4 AF becomes available:
Nexus-2(config)# install feature-set mpls
Nexus-2(config)# feature-set mpls
Nexus-2(config)# feature mpls l3vpn
Now going back to the BGP configuration, you can see vpnv4 is now an option:
vpnv4 Configure IPv4 VPN address-family
vpnv6 Configure IPv6 VPN address-family
Hope that helps get you started on this.
09-19-2022 08:35 AM - edited 09-19-2022 08:37 AM
but you mention VRF-lite why you not use it ?
I think the link below give you answer, you can use one P2P and using tag to separate the traffic for each VRF
https://wonderdam.altervista.org/blog/multi-vrf-ce-vrf-lite/
09-19-2022
09:35 AM
- last edited on
09-20-2022
02:41 AM
by
Translator
I believe
Nexus
is the keyword here. There is no address-family vpnv4 on N9K.
09-19-2022 09:49 AM - edited 09-19-2022 09:51 AM
friend
there are two way to exchange VRF traffic
if the Peer is direct connect then use VRF lite
if the Peer is indirect connect then we use MPLS
here I think the both NSK direct connect ?
09-19-2022 11:33 AM
Thank you for clarification @MHM Cisco World
Could you please include a configuration example specific to NX-OS showing how to bring up iBGP peering between two directly connected boxes allowing them to exhange vpnv4 NLRIs ?
09-19-2022 12:37 PM
09-19-2022 02:33 PM
Hi there!
feature bgp
router bgp 65111
router-id 1.1.1.1
network 1.1.1.1/32
neighbor 2.2.2.2
remote-as 65111
send-community
vrf BLUE
vrf RED
interface loopback0
mtu 9216
no ip redirects
no ipv6 redirects
no shutdown
feature bgp
router bgp 65111
router-id 2.2.2.2
network 2.2.2.2/32
neighbor 1.1.1.1
remote-as 65111
send-community
vrf BLUE
vrf RED
interface loopback0
interface loopback1
description VRF RED
vrf member RED
interface loopback2
vrf member BLUE
mtu 9216
no ip redirects
no ipv6 redirects
no shutdown
09-20-2022 01:24 AM
Thank you @Andrea Testino
As I mentioned, my problem is that not vpnv4 afi is available:
r1#(config)# router bgp 65300
r1#(config-router)# address-family ?
This is a cisco Nexus9000 C93180YC-FX Chassis running NXOS: version 9.3(6)
r1(config-router)# sh feature | i enabled
bash-shell 1 enabled
bfd 1 enabled
bgp 1 enabled
dhcp 1 enabled
hsrp_engine 1 enabled
icam 1 enabled
interface-vlan 1 enabled
lacp 1 enabled
lldp 1 enabled
netconf 1 enabled
ospf 1 enabled(not-running)
ospf 2 enabled(not-running)
ospf 3 enabled(not-running)
ospf 4 enabled(not-running)
ospf 5 enabled(not-running)
ospf 6 enabled(not-running)
ospf 7 enabled(not-running)
ospf 8 enabled(not-running)
ospf 9 enabled(not-running)
ospf 10 enabled(not-running)
ospf 11 enabled(not-running)
ospf 12 enabled(not-running)
ospf 13 enabled(not-running)
ospf 14 enabled(not-running)
ospf 15 enabled(not-running)
ospf 16 enabled(not-running)
pim 1 enabled
restconf 1 enabled
scpServer 1 enabled
sftpServer 1 enabled
sshServer 1 enabled
tacacs 1 enabled
tunnel 1 enabled
udld 1 enabled
r1(config-router)#
What am I missing ? Some feature perhaps ?
09-20-2022 01:27 AM
Nexus-2(config)# install feature-set mpls Nexus-2(config)# feature-set mpls Nexus-2(config)# feature mpls l3vpn
these feature you missing as @Andrea Testino mention above
09-20-2022 01:37 AM
My bad, did not read through but stopped at first config
Much appreciate your help
09-20-2022 01:39 AM
You are so so welcome any time
