Nexus Error
2015 Dec 28 00:44:30.949 BC5NX02 22670]: CLIC-3-FAILED_UNLINK_FILE: Couldn't unlink file /rd/fifo/cli-fifo-22670-0
2015 Dec 29 00:43:44 BC5NX02 %DAEMON-3-SYSTEM_MSG: error: setsockopt IP_TOS 16: Invalid argument: - sshd[1522]
2015 Dec 29 00:44:17 BC5NX02 %DAEMON-3-SYSTEM_MSG: error: setsockopt IP_TOS 16: Invalid argument: - sshd[1601]
Michael J. Johnson
Most likely you are hitting CSCue13437.
This is a cosmetic issue. I would recommend to upgrade to the latest release if these messages are really annoying and need to be addressed.
-Raj
Rajeshkumar Gatti
I can probably help if you can provide the platform details and version running on the device?
-Raj
BC5NX02#
BC5NX02# sho ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2011, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 1.0.37
  loader:    version N/A
  kickstart: version 4.1(2)E1(1g)
  system:    version 4.1(2)E1(1g)
  BIOS compile time:       09/29/09
  kickstart image file is: bootflash:/n4000-bk9-kickstart.4.1.2.E1.1g.bin
  kickstart compile time:  7/28/2011 0:00:00 [07/28/2011 09:33:38]
  system image file is:    bootflash:/n4000-bk9.4.1.2.E1.1g.bin
  system compile time:     7/28/2011 0:00:00 [07/28/2011 09:21:07]
Hardware
  cisco Nexus 4000 Chassis ("20x10GE/supervisor")
  Motorola, e500v2  with 2076512 kB of memory.
  Processor Board ID FOC15490JLV
  Device name: BC5NX02
  bootflash:     609168 kB
Kernel uptime is 1197 day(s), 23 hour(s), 58 minute(s), 44 second(s)
Last reset at 559620 usecs after  Mon Sep 17 12:30:35 2012
  Reason: Reset Requested by CLI command reload
  System version: 4.1(2)E1(1g)
  Service:
plugin
  Core Plugin, Ethernet Plugin
Michael J. Johnson
-Raj
