NM-16ESW-1GIG configuration
biplobkhan
I have 3945 Router and I have bought NM-16ESW-1G1G card. After installed the card no interface  shows on show ip interface brief or Show run command . When i end the switch module then i have found the interface. previously i have worked on NM-16ESW card on my 3845 router where interface card interface shows in my show run and interface command and i have assign IP and crypto map fro my Branch.
So my question is NM-16ESW-1G1G is different then NM-16ESW card ? if not then why i can not find interface.
if Different then i have need to configure interfcae by enter the switch module seperately ?  Please assist with configure Guide.
Iqbal
If you have 3945E then,This module is not supported in the 3945E.
3945 supported NM-16ESW-1GIG.
7 Replies 7
Sandeep Choudhary
HI IQBAL,
do you have this: network module adapter card (SM-NM-ADPTR).
Cisco 3900 Series
NM-16ESW and NM-16ESW-1GIG only*
*Note:  Of the modules outlined in this datasheet, only the NM-16ESW can be  used in the Cisco 2911, 2921, 2951, 3925, 3945 routers. Support for the  NM-16ESW in the 2911, 2921, 2951, 3925, and 3945 will be via the network  module adapter card (SM-NM-ADPTR).
Cisco 3900 Series
NM-16ESW and NM-16ESW-1GIG only 15.0(1)M*, IP Base License
see if you have this (Minimum Supported Cisco IOS Release)
Please rate if it helps.
Hi Sandeep
my 3945 router has universal IOS and come with NM-16ESW-1GIG with the router. Required any network module adapter ? now I can access the switch card by access switch module seperately in router.
so if i cange the IOS then i can see the 15 interface in router ?
Iqbal
UNiversal IOS:
S39UK9-15001M
HI Iqbal,
IOS is ok, can you show me the version of router.
is it E series or wt ??
sh ver ???
Cisco 3945 Security Bundle w/SEC license PAK
collecting the Sh ver.
