Problem with Cisco 1721 as PPTP client
jguandalini
Hello, I tried to configure a 1721 router, but he can't connect in my server. I follow various how-to in the Internet, but anyone could help me.
Thanks.
running-config:
version 12.4
service password-encryption
service internal
hostname aaa-pptp
boot-start-marker
boot system flash:
boot system flash:c1700-advsecurityk9-mz.124-25d.bin
boot-end-marker
enable secret 5 $1$h8tw$jsHfGN8e7Cl7xL3J2keZM.
no aaa new-model
no ip gratuitous-arps
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip multicast-routing
vpdn enable
vpdn-group PPTP
request-dialin
  protocol pptp
  rotary-group 2
initiate-to ip 1.1.1.1
interface FastEthernet0
ip address 172.20.4.123 255.255.0.0
speed auto
interface Serial0
no ip address
shutdown
interface Dialer2
mtu 1460
ip address negotiated
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer string 123456
dialer vpdn
dialer-group 2
no cdp enable
ppp pfc local request
ppp pfc remote apply
ppp encrypt mppe auto
ppp chap hostname userpptp
ppp chap password 7 09191F504952374A5E
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.20.4.85
ip route 10.239.239.1 255.255.255.255 Dialer2
no ip http server
no ip http secure-server
dialer-list 2 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
password 7 094F471A1A0A
login
end
Debug is:
*Mar  1 22:55:45.491: %DIALER-4-MTU_WARNING: Current MTU setting of 1500 on Virtual-Access1 is being overwritten by setting of 1460 defined by Dialer2.
*Mar  1 22:55:45.495: Vi1 PPP: Phase is DOWN, Setup
*Mar  1 22:55:46.135: Vi1 Tnl/Sn 40/40 PPTP: VPDN session up
*Mar  1 22:55:46.143: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Mar  1 22:55:46.143: Vi1 PPP: Using dialer call direction
*Mar  1 22:55:46.143: Vi1 PPP: Treating connection as a callout
*Mar  1 22:55:46.143: Vi1 PPP: Session handle[7000075] Session id[38]
*Mar  1 22:55:46.143: Vi1 PPP: Phase is ESTABLISHING, Active Open
*Mar  1 22:55:46.147: Vi1 PPP: No remote authentication for call-out
*Mar  1 22:55:46.147: Vi1 LCP: O CONFREQ [Closed] id 1 len 16
*Mar  1 22:55:46.147: Vi1 LCP:    MRU 1460 (0x010405B4)
*Mar  1 22:55:46.147: Vi1 LCP:    MagicNumber 0x0D73CD92 (0x05060D73CD92)
*Mar  1 22:55:46.147: Vi1 LCP:    PFC (0x0702)
*Mar  1 22:55:46.255: Vi1 LCP: I CONFREQ [REQsent] id 0 len 25
*Mar  1 22:55:46.255: Vi1 LCP:    MRU 1400 (0x01040578)
*Mar  1 22:55:46.255: Vi1 LCP:    AuthProto EAP (0x0304C227)
*Mar  1 22:55:46.255: Vi1 LCP:    Mag.
Success rate is 0 percent (0/1)
autotrac-pptp#icNumber 0x2801235C (0x05062801235C)
*Mar  1 22:55:46.255: Vi1 LCP:    PFC (0x0702)
*Mar  1 22:55:46.259: Vi1 LCP:    ACFC (0x0802)
*Mar  1 22:55:46.259: Vi1 LCP:    Callback 6  (0x0D0306)
*Mar  1 22:55:46.259: Vi1 LCP: O CONFREJ [REQsent] id 0 len 7
*Mar  1 22:55:46.275: Vi1 LCP: I CONFACK [REQsent] id 1 len 16
*Mar  1 22:55:46.275: Vi1 LCP:    MRU 1460 (0x010405B4)
*Mar  1 22:55:46.275: Vi1 LCP:    MagicNumber 0x0D73CD92 (0x05060D73CD92)
*Mar  1 22:55:46.275: Vi1 LCP:    PFC (0x0702)
*Mar  1 22:55:46.375: Vi1 LCP: I CONFREQ [ACKrcvd] id 1 len 22
*Mar  1 22:55:46.375: Vi1 LCP:    MRU 1400 (0x01040578)
*Mar  1 22:55:46.375: Vi1 LCP:    AuthProto EAP (0x0304C227)
*Mar  1 22:55:46.375: Vi1 LCP:    MagicNumber 0x2801235C (0x05062801235C)
*Mar  1 22:55:46.375: Vi1 LCP:    PFC (0x0702)
*Mar  1 22:55:46.375: Vi1 LCP:    ACFC (0x0802)
*Mar  1 22:55:46.379: Vi1 LCP: O CONFNAK [ACKrcvd] id 1 len 8
*Mar  1 22:55:46.379: Vi1 LCP:    MRU 1460 (0x010405B4)
*Mar  1 22:55:46.495: Vi1 LCP: I CONFREQ [ACKrcvd] id 2 len 22
*Mar  1 22:55:46.495: Vi1 LCP:    MRU 1400 (0x01040578)
*Mar  1 22:55:46.495: Vi1 LCP:    AuthProto EAP (0x0304C227)
*Mar  1 22:55:46.495: Vi1 LCP:    MagicNumber 0x2801235C (0x05062801235C)
*Mar  1 22:55:46.495: Vi1 LCP:    PFC (0x0702)
*Mar  1 22:55:46.499: Vi1 LCP:    ACFC (0x0802)
*Mar  1 22:55:46.499: Vi1 LCP: O CONFNAK [ACKrcvd] id 2 len 8
*Mar  1 22:55:46.499: Vi1 LCP:    MRU 1460 (0x010405B4)
*Mar  1 22:55:46.615: Vi1 LCP: I CONFREQ [ACKrcvd] id 3 len 22
*Mar  1 22:55:46.615: Vi1 LCP:    MRU 1460 (0x010405B4)
*Mar  1 22:55:46.615: Vi1 LCP:    AuthProto EAP (0x0304C227)
*Mar  1 22:55:46.615: Vi1 LCP:    MagicNumber 0x2801235C (0x05062801235C)
*Mar  1 22:55:46.615: Vi1 LCP:    PFC (0x0702)
*Mar  1 22:55:46.615: Vi1 LCP:    ACFC (0x0802)
*Mar  1 22:55:46.619: Vi1 LCP: O CONFACK [ACKrcvd] id 3 len 22
*Mar  1 22:55:46.619: Vi1 LCP:    MRU 1460 (0x010405B4)
*Mar  1 22:55:46.619: Vi1 LCP:    AuthProto EAP (0x0304C227)
*Mar  1 22:55:46.619: Vi1 LCP:    MagicNumber 0x2801235C (0x05062801235C)
*Mar  1 22:55:46.619: Vi1 LCP:    PFC (0x0702)
*Mar  1 22:55:46.619: Vi1 LCP:    ACFC (0x0802)
*Mar  1 22:55:46.619: Vi1 LCP: State is Open
*Mar  1 22:55:46.619: Vi1 PPP: Phase is AUTHENTICATING, by the peer
*Mar  1 22:55:46.755: Vi1 EAP: I REQUEST  IDENTITY id 28 len 5
*Mar  1 22:55:46.755: Vi1 EAP: O RESPONSE IDENTITY id 28 len 18 from "aaa-pptp"
*Mar  1 22:55:56.619: Vi1 AUTH: Timeout 1
*Mar  1 22:55:56.895: Vi1 LCP: I TERMREQ [Open] id 5 len 16 (0x2801235C003CCD74000003A2)
*Mar  1 22:55:56.899: Vi1 LCP: O TERMACK [Open] id 5 len 4
*Mar  1 22:55:56.899: Vi1 PPP: Sending Acct Event[Down] id[29]
*Mar  1 22:55:56.899: Vi1 PPP: Phase is TERMINATING
*Mar  1 22:55:57.027: Vi1 VPDN: Resetting interface
*Mar  1 22:55:57.031: Vi1 PPP: Block vaccess from being freed [0x10]
*Mar  1 22:55:57.031: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
*Mar  1 22:55:57.031: Vi1 LCP: State is Closed
*Mar  1 22:55:57.035: Vi1 PPP: Phase is DOWN
*Mar  1 22:55:57.035: Vi1 PPP: Unlocked by [0x10] Still Locked by [0x2]
*Mar  1 22:55:57.035: Vi1 PPP: Unlocked by [0x2] Still Locked by [0x0]
*Mar  1 22:55:57.035: Vi1 PPP: Free previously blocked vaccess
Hello Jean,
If I am not wrong but I think you can only configure a cisco router as  PPTP server
regards
harish.
The problem was solved.
In interface dialer 2 section, I've added these lines:
refuse eap
refuse pap
refuse chap
Immediately the pptp has connected.
Thanks for the attention.
