NM-2FE2W-V2 Not getting Detected...
danishbaig
i have a 3640 router and was running with Nm-1E2W Network Module i have replaced it with NM-2FE2W-V2, this module is not getting detected by the router. below given is Version & Diag Information. Please advice.
IOS (tm) 3600 Software (C3640-IO3S56I-M), Version 12.1(5)T8, RELEASE SOFTWARE (
fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Mon 07-May-01 19:58 by ccai
Image text-base: 0x60008950, data-base: 0x612EC000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (f
c1)
ROM: 3600 Software (C3640-IO3S56I-M), Version 12.1(5)T8, RELEASE SOFTWARE (fc1)
Router uptime is 6 minutes
System image file is "flash:c3640-io3s56i-mz_121-5_T8.bin"
cisco 3640 (R4700) processor (revision 0x00) with 45056K/4096K bytes of memory.
Processor board ID 26758246
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
8 Low-speed serial(sync/async) network interface(s)
8 Voice FXS interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Abbar-Jed# sh diag
Slot 0:
Unknown (type 919) Port adapter
Port adapter is disabled
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
Top Assy. Part Number : 800-21601-02
Board Revision : D0
Deviation Number : 0-8610
Fab Version : 01
PCB Serial Number : FOC09200SJG
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 97 41 01 00 C0 46 03 20 00 54 61 02
0x10: 42 44 30 80 00 00 21 A2 02 01 C1 8B 46 4F 43 30
0x20: 39 32 30 30 53 4A 47 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
the link posted by Sankar yesterday is actually very useful:
For the NM-1FE2W-V2 and NM-2FE2W-V2 the minimum level IOS is 12.2(12)M and 12.2(13)T.
Since you are running 12.1(5)T8, you might want to try and upgrade the IOS...
HTH,
GP
Thanks for the reply.
Do you know where I could find the IOS for a 2600 series? Iv'e checked the downloads page and can't find the IOS for my router (2620)
Any help would be great,
-B
