SCP with vrf takes a long time to copy file.
Mark Wright
If I copy a file from the 881 router without VRF it takes  0.776 secs (180 bytes/sec) to copy 140 bytes.
I setup VRF and set my Ip ssh source-interface to FastEthernet4 it takes 11.188 secs (13 bytes/sec) to copy 140bytes.
In both I copied the same file to the same system.
Is there a route or some other setting that could speed this up?
-Mark
Mark Wright
check to see if you device supports the new vrf definition
conf t
vrf definition ?
If it does change to vrf definition from ip vrf.
I found this speeds up scp.
Mark Wright
conf t
vrf definition ?
