06-01-2006 06:56 PM - edited 03-03-2019 12:52 PM
I have a 2811 router. I am trying to get the NME to connect through the router. I have tried just about everything. I can access the switch and the router but I can't get the network that is connected to the switch to go out the router interfaces. I have configured vlan interfaces and sub interfaces on the router.
06-01-2006 08:07 PM
Can you post your running configuration here? Maybe show where the host are connected, their ip address, and their gateway, what network and where these hosts connected to the NME is trying to get to? The NME is a switch module and needs to be configured as if it's an external switch.
Maybe this link will be of some help:
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_feature_guide09186a0080415bae.html
Please rate helpful posts.
06-02-2006 07:18 AM
I can post the configuration that I have on there now but it would be one of many. I don't have a set config yet. Right now I am doing a prof of concept.
hostname
boot-start-marker
boot system flash:c2800nm-advipservicesk9-mz.124-7.bin
boot-end-marker
no aaa new-model
resource policy
ip cef
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.2 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet1/0
ip address 172.1.1.1 255.255.255.0
(I had to assign an address to the G1/0 so I could access the switch portion)
interface GigabitEthernet1/0.200
encapsulation dot1Q 200
ip address 10.10.10.1 255.255.255.0
no snmp trap link-status
router ospf 1
log-adjacency-changes
network 192.168.0.1 0.0.0.0 area 0.0.0.0
network 192.168.1.2 0.0.0.0 area 0.0.0.0
network 10.10.10.1 0.0.0.0 area 0.0.0.0
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
Here is the switch config
! Last configuration change at 17:57:37 UTC Wed May 31 2006
! NVRAM config last updated at 18:00:57 UTC Wed May 31 2006
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
switch 1 provision NME-16ES-1G-P
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
switchport access vlan 200
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface Vlan1
no ip address
shutdown
interface Vlan200
no ip address
ip classless
ip http server
control-plane
--More--
ip classless
ip http server
control-plane
line con 0
line vty 5 15
end
Switch#
Switch#
If there is a config that I could follow. I can modify as I need. I just wanted to get the data/voice to go through the router. Thanks for the help.
06-02-2006 10:49 AM
It works!!! The switch card has two virtual gig interfaces g1/0 and g1/0/2. I had to put a ip address on the g1/0 in order to access the switch module. I created a vlan with an ip address that was in the same subnet that the ip address of g1/0 was in. I then placed the g1/0/2 and all other switch ports in this vlan. I know "duu" everyone can't be router gods!! I am sure there are cleaner ways to do this without using two ip address. Thanks to Tim.
