no best path(BGP)
admin_2
Level 3
Level 3
what is wrong?
ping test is good:both path
C6509--R#sh ip bgp 10.10.6.19
BGP routing table entry for 10.10.0.0/16, version 0
Paths: (2 available, no best path)
Not advertised to any peer
1000 2000, (received-only)
200.100.200.150 from 200.100.200.150 (200.100.200.150)
Origin IGP, localpref 100, valid, external
Community: 312354000
3000 2000, (received-only)
150.100.100.109 from 150.100.100.109 (172.30.51.171)
Community: 248119000
router bgp 5000
no synchronization
bgp log-neighbor-changes
network 220.1.54.0
redistribute static
neighbor 150.100.100.109 remote-as 3000
neighbor 150.100.100.109 ebgp-multihop 255
neighbor 150.100.100.109 soft-reconfiguration inbound
neighbor 150.100.100.109 route-map ASPREPEND out
neighbor 150.100.100.109 filter-list 10 in
neighbor 150.100.100.109 filter-list 100 out
neighbor 200.100.200.150 remote-as 1000
neighbor 200.100.200.150 ebgp-multihop 255
neighbor 200.100.200.150 soft-reconfiguration inbound
neighbor 200.100.200.150 filter-list 20 in
neighbor 200.100.200.150 filter-list 100 out
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip route 0.0.0.0 0.0.0.0 20.20.20.1
ip route 220.1.54.0 255.255.254.0 100.246.1.1
ip route 150.100.100.109 255.255.255.255 20.20.20.1
ip route 200.100.200.150 255.255.255.255 10.10.10.1
route-map ASPREPEND permit 10
set as-path prepend 5000 5000
ip as-path access-list 10 permit ^(3000_)+$
ip as-path access-list 20 permit ^(1000_)+$
ip as-path access-list 100 permit ^$
Harold Ritter
Both paths are in "received-only" mode, which means that they have been filtered by an inbound policy but kept because "soft-reconfiguration inbound" is configured.
The as-path ACLs 10 and 20 are not allowing the as-paths received from your two neighbors.
as-path acl 10 only allows one or more repetition of ASN 3000, which is different than "3000 2000" received from 150.100.100.109.
as-path acl 20 only allows one or more repetition of ASN 1000, which is different than "1000 2000" received from 200.100.200.150.
Hope this helps,
Dear Harold, I have solved my issue by seeing you comment. Thanks.
I'm glad to hear I could help.
Thanks for the comment
