No debug output displayed on 3745 while SSH or Telnet
yavuz_sab
IOS 12.3(4)T4 on 3745.
While Telnet, SSH or console into router we see no debug output even after turning Terminal monitor, we can only see the show outputs, etc. While consoled into the 3745 we see nothing there is No prompt or any messages at all.
We tried replacing the console cable and placed it on different PCs or laptop still no go. I was thinking of reloading the router tomorrow night, but want to check if anyone has come across this problem. It was all working in the past without any changes.
Is there like a command i need to add, etc. But i am 100% sure its all good on the 3745.
Cheers!
-Yavuz
paddyxdoyle
Level 6
Level 6
Commands to try are:
# logging on
# logging console debugging
# logging monitor debugging
# terminal monitor
PJD
Thanks i will try this and let you know. As for not being able to console into the router, what could be the reason for this?
Cheers!
Yavuz
