No distribute learned networks (EIGRP)
jegobc15c0
Hi!
Which command can I use so the router do not redistribute learned networks, only the configured ones locally, only using one EIGRP process.
Thanks.
Richard Burts
I do not understand what you are asking. If you do not want EIGRP to redistribute routes then do not configure redistribution under router EIGRP. If you do not want EIGRP to advertise some routes that it has learned then you can configure distribute lists to control what is advertised.
If these points do not address your question then please provide clarification of the question.
Rick
Rick
Richard Burts
Rick
Rick
I've already done it, thanks. I've used "eigrp stub connected"
Regards.
