no internet access on Ethernet ports
Ralf110666
Hello all,
for a function test i need to get internet connection with a IR 829. before i worked allready with a 809 and used the setup on that 829...unfortunately not successful. I modified it here and there a bit now i am able to ping 8.8.8.8 via console port. but not over GE 1 to 4. on a connected computer i get an IP address from the dhcp pool i can also ping the 829 from a connected computer but i can not ping 8.8.8.8 and i have also no DNS.
The actual config looks as follows :
~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.04.08 09:04:27 =~=~=~=~=~=~=~=~=~=~=~=
IR800#show
*Apr 8 08:00:36.781: %SYS-5-CONFIG_I: Configured from console by console runnin
Building configuration...
Current configuration : 3821 bytes
! Last configuration change at 08:00:36 UTC Wed Apr 8 2020
version 15.7
hostname IR800
boot-start-marker
boot-end-marker
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 900
ignition undervoltage threshold 11
--More--
IR800#how     show running
version 15.7
hostname IR800
boot-start-marker
boot-end-marker
no aaa new-model
--More--  !
no ignition enable
ip dhcp excluded-address 192.168.7.1
ip dhcp pool dpool1
import all
network 192.168.7.0 255.255.255.0
dns-server 192.168.7.1
domain-name test
--More--   default-router 192.168.7.1
ip domain name Spessart
ip name-server 192.168.7.1
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid IR829-2LTE-EA-EK9 sn FGL23259005
redundancy
--More--  !
controller Cellular 0
lte modem link-recovery disable
controller Cellular 1
no lte gps enable
interface GigabitEthernet0
no ip address
--More--   shutdown
interface GigabitEthernet1
switchport mode access
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface Wlan-GigabitEthernet0
no ip address
interface GigabitEthernet5
no ip address
--More--   shutdown
duplex auto
speed auto
interface Cellular0/0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string lte
dialer-group 1
ipv6 address autoconfig
interface Cellular1/0
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
--More--  !
interface Cellular0/1
no ip address
encapsulation slip
interface Cellular1/1
no ip address
encapsulation slip
interface wlan-ap0
no ip address
shutdown
interface Vlan1
ip address 192.168.7.1 255.255.255.0
ip nat inside
interface Async0
no ip address
encapsulation scada
interface Async1
--More--   no ip address
encapsulation scada
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT interface Cellular0/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/0
ip route 0.0.0.0 0.0.0.0 Vlan1
ip route 8.8.8.8 255.255.255.255 Cellular0/0
ip route 0.0.0.0 0.0.0.0 Vlan1 dhcp
ip access-list extended NAT
permit ip host 0.0.0.0 any
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipv6 permit
ipv6 ioam timestamp
--More--  !
control-plane
line con 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
no exec
transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
rxspeed 150000000
txspeed 50000000
line 4
no activation-character
no exec
transport preferred none
transport input all
line 8
--More--   no exec
rxspeed 150000000
txspeed 50000000
line 9
script dialer lte
no exec
line 15
no exec
line 1/3 1/6
transport output none
stopbits 1
line vty 0 4
login
transport input none
no scheduler max-task-time
--More--  no iox hdm-enable
iox client enable interface GigabitEthernet5
no iox recovery-enable
end
Best regards
ralf
Jon Marshall
Make these changes -
1) In your DHCP pool setup -
dns-server 8.8.8.8  + any others you want to add
2) Your NAT access-list -
permit ip 192.168.7.0 0.0.0.255 any
Jon
Jon Marshall
Jon
Thanks a lot Jon. It seem to be fine now.
Best regards
Ralf
Hello
Your nat access-list isn’t correct and you have multiple default routes pointing towards various egress interfaces
Suggest you change this and test again.
no ip route 0.0.0.0 0.0.0.0 Vlan1
no ip route 8.8.8.8 255.255.255.255 Cellular0/0
no ip route 0.0.0.0 0.0.0.0 Vlan1 dhcp
no ip access-list extended NAT
Kind Regards
Paul
