No IOS - can not access multilayer Switch (catalyst 3750)
azim.yoldash
Working on my CCNA w/ live equip, I accidentley deleted the hardware IOS- yes, beginners mistake.  Upon bootup, I do not get a command prompt.  I tried the recovery procedure(hold mode button before power up) recommended by Cisco to no avail.  My issue is I use SecureCRT & the charaters/font is ineligible.  Here is an example of what I see when typing; "þæb Bûÿÿûýÿ¿¿ÿÿ".  Currently, the SYST indicator is blinking & I have no access.
Assistance appreciated
Leo Laohoo
You got the wrong baud rate on your SecureCRT.  You need to adjust it to the correct speed.
At 9600 on CRT, what is the correct baud rate?
Nevermind, got it.  Remember setting switch for 115200 before attempting to upload IOS bin via xmodem.  Thanks!
