No option 125
comunicacoes
I've implemented DHCP Snooping and Dynamic ARP Inspection in a 2960-X Switch. Before I replicate the configuration to the other switches in my company I need to figure out how to correct/eliminate the DHCPD: no option 125 message that's filling my logs. I'm using a Microsoft Windows DHCP Server.
Is there any way to correct this message without re-configuring the DHCP Server?
Thank you very much,
Claudio
Hi Claudio,
I also ran into this problem with the same switch.
After reading the manual I removed the line
no service dhcp
from the configuration and it seems like this solved my problem.
I hope this helps in case someone still has this problem.
Kind regards
Lennart
