Cisco ASDM-IDM launcher unable
Hello guys
Im new here and beginner on network system.
Okey i have using Cisco asa 5505 Routerboard. When i launch ASDM-IDM Launcher it tells me Unable to launch device manager from IP ... how to fix this.
On java console
OK button clicked
java.net.ConnectException: Connection timed out: connect
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.security.ssl.SSLSocketImpl.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
Khasarvaani
5 Replies 5
marce1000
 - Seems like the asa is not responding, is it up and running ? Some other causes may include :
  •  The ASA ASDM-service is down
  •  The ASA takes longer to respond then the ASDM timeout period
  •  You have a firewall that is blocking requests to the ASA
 M.
Hello Marce1000
Thanks for the responding
1. how to check asa asdm services ?  on services.msc there is no asa services.
firewall not blocking the requests to the ASA,
I was configuring VPN on the RB and after that ASA had this issue.
balaji.bandi
From the Devivce you launching ASDM, are you able to ping the ASA IP Address  ( what is the source device IP and ASA IP address)
connect the console and  post the below output :
#show verison
# dir
# show run asdm
#show run
BB
Ping is not going to ASA ip address or device either.
What console am i have to connect sorry im beginner.
Khasar
check this document how to connect console :
https://www.cisco.com/c/en/us/td/docs/security/asa/quick_start/5505/5505-poster.html
BB
