No OSPF, but debug ip ospf events generate output
Denis Orlov
Hello everybody.
I faced with strange behavior of Cisco 2901.
I strat ospf process on router, do some ospf manipulations and than turn off ospf with
R1(config)#no router ospf 1
But after that when I start to change my config: shut/no shut interfaces
I see OSPF debug messages
R1(config-fr-dlci)#interface Serial0/0/0.5 point-to-point
R1(config-subif)#sh
R1(config-subif)#
Jul  5 12:33:13.004: OSPF EVENT Se0/0/0.5: Route adjust
R1(config-subif)#
R1(config-subif)#
R1#sh
Jul  5 12:34:15.076: %SYS-5-CONFIG_I: Configured from console by consoleip pro
R1#sh ip protocols
*** IP Routing is NSF aware ***
How it can be? Thereis no OPSF process on R1.
6 Replies 6
Sandeep Choudhary
Try to use thisese command:
clear ip ospf process
If you did some redistribution then use:
clear ip ospf redistribution
please rate if it helps.
I'm already try this command
Seem to me, gentlemens, that "show ip protocols" tell us false.
Did you check the licence? I had a similar issue on one 2911 and it was all about the license ... of course the last thing i have checked
hope it helps
Alessio
Very interesting.
And how licensing lead to such effect?
Explain please.
Hi Denis,
from the IOS 15 you do not have anymore the features enabled as per 12.4 or previous IOS lines. when you buy the 2900 series (as others) you now get the IP Base license and then you need to upgrade that license with the features you require:
- security
- unified communications
- data
- voice
or a combination of those. In my case, i hadn't upgraded my 2911 and i could not configure BGP on it even if i could see some BGP commands.
Hope it helps
Alessio
Are you read the question?!
I'm asking about strange behavior of OSPF.
Why OSPF continues to generate debug messages, when I turn OSPF off?
