Cisco ISR G2 Licensing
ahmad82pkn
Level 3
Level 3
Hi , i am new on buying Cisco ISR series.
i was planning to buy cisco 2901 Router.
i need to create SITE TO SITE IPSEC VPN on that, i just need to know, when i order router , i need to buy additional SECK9 package?
What all i need to tell the seller, i need Cisco 2901 with SECK9 Technology pack  , and it will have IPBASE K9 built in.
Correct?
hi there,
here what you need:
CISCO2911/K9 Cisco 2911 w/3 GE,4 EHWIC,2 DSP,1 SM,256MB CF,512MB DRAM,IPB
S29NPEK9-15202T Cisco 2901-2921 IOS UNIVERSAL - NO PAYLOAD ENCRYPTION
SL-29-SECNPE-K9 SEC No Payload Encryption  License  for Cisco 2901-2951
In my case was of course for a 2911. You can choose also with payload encryption anyway
up to you and your needs.Verify of course the crypto capabilities with the IOS i have suggested!!!!! It works for me
Hope this helps
Alessio
Giuseppe Larosa
Hello Ahmad,
your understanding looks like correct
see
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985.html#wp9000694
SECK9  license is added over IPbaseK9 see the first table in the above document
Hope to help
Giuseppe
