No output on show run
bedevere.curry
We have an issue with our 7200. We can't output the show run, wr term, other show command works. Is there a way to resolve this?
thanks
spdum1edmz2r01#show version
IOS (tm) 7200 Software (C7200-IS-M), Version 12.0(7)XE1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC:Home:SW:IOS:Specials for info
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Fri 04-Feb-00 21:31 by lstringr
Image text-base: 0x60008900, data-base: 0x60FF4000
ROM: System Bootstrap, Version 11.1(13)CA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTFLASH: 7200 Software (C7200-BOOT-M), Version 12.0(10)S, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
spdum1edmz2r01 uptime is 11 weeks, 5 days, 5 hours, 30 minutes
System returned to ROM by reload at 21:16:29 BRA Thu Mar 29 2007
System restarted at 21:18:06 BRA Thu Mar 29 2007
System image file is "slot0:c7200-is-mz.120-7.XE1"
cisco 7206 (NPE200) processor with 57344K/8192K bytes of memory.
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
6 slot midplane, Version 1.3
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
24 Ethernet/IEEE 802.3 interface(s)
2 FastEthernet/IEEE 802.3 interface(s)
125K bytes of non-volatile configuration memory.
4096K bytes of packet SRAM memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
4096K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x102
spdum1edmz2r01#show rim
spdum1edmz2r01#show run
spdum1edmz2r01#show running-config
spdum1edmz2r01#dir nv
spdum1edmz2r01#dir nvram:
Directory of nvram:/
1 -rw- 53202 <no date> startup-config
2 ---- 26 <no date> private-config
3 -rw- 53202 <no date> underlying-config
129016 bytes total (75814 bytes free)
spdum1edmz2r01#dir /all flaa
spdum1edmz2r01#dir /all flash:
Directory of slot0:/
1 -rw- 9239932 Jun 22 2000 23:01:07 c7200-is-mz.120-7.XE1
2 -rw- 273384 Dec 07 2002 23:30:52 config
20578304 bytes total (11064732 bytes free)
spdum1edmz2r01#
guruprasadr
Level 7
Level 7
HI, [Pls Rate if Helps]
Error in: Configuration Register Setting...
Your COnfiguration Register set is: 0x102
Set your Configuration Register Value to:
"Configuration register is 0x2102"
INFO: On power-up or reload, this router will load the IOS image stored in flash-RAM
(assuming one exists). If no valid IOS image or flash-RAM exists, this router will attempt to boot in order of following methods:
- boot system commands
- a TFTP-server (using a default IOS image filename)
INFO: On power-up or reload, this router will load it's configuration from a file
stored in NVRAM.
WARNING: On power-up or reload, if an error occurs with it's prescribed IOS boot method(s), this router will not boot into the fall-back (reduced) IOS image stored on ROM (sometimes called ROM-boot or boot-strap mode)
TRY THIS: To restore the router's fall-back ROM-boot to default function, enter
configuration mode and reset the configuration register with the 'config-register' command. Set the 13th low-order bit (from the right) of the register to binary 0. (You'll have to convert the final register value from binary to hexadecimal
0xABCD) for the 'config-register' command.)
PLS RATE if HELPS
Best Regards,
Guru Prasad R
