no ping - 2 routers connected via cross over cable
witek77
Hello Everyone.
I have bought 2 cisco 2600 routers. Got them connected with cross over cable, configured the interfaces on both sides and get no ping getting from one side to the other? Can anyone tell me why,please? IP adresses for both connected interfaces are 192.168.2.1 and 192.168.2.2 with 255.255.255.0 mask. I've tried full-duplex and half-duplex. still get no signal either on putty connected to console port on one of them or from laptop connected to the other Ethernet port?
2 Accepted Solutions
looking at the output:
bartek#show interface
Ethernet0/1 is up, line protocol is down
Hardware is AmdP2, address is 000a.41d5.5fa1 (bia 000a.41d5.5fa1)
Description: SIEC LOKALNA 192.168.2.0
Internet address is 192.168.2.2/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
--> reliability 166/255, txload 1/255, rxload 1/255
witek#show interface
FastEthernet0/0 is up, line protocol is down
Hardware is AmdFE, address is 000a.b783.a480 (bia 000a.b783.a480)
Internet address is 192.168.2.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
--> Full-duplex, Auto Speed, 100BaseTX/FX
You are connecting a 10MB to a 100MB port. As far as I recall, the 10MB ports only support half duplex, but either way, set the speed and duplex to be the same on both sides (speed/duplex under the interface settings).
Also, the reliability of your Ethernet0 interface is (much) less than 255, which usually indicates a physical problem (either with the cable or with the port). Try another port on the bartek router (preferably a 100MB port).
Witek
Thanks for the additional information. I am slightly surprised to see that the computer has both an active wireless connection and an active Ethernet connection.
Pretty clearly when you ping from 1700 to computer it is using the Ethernet connection on the computer - and it works. I wonder when you attempt to ping from the computer if perhaps it is using the wireless connection? Would you turn off the wireless on the computer and try the ping when the computer has only a single active interface - Ethernet?
Rick
22 Replies 22
Hello
Have you tried to change your cable?
Are the ports enabled
int x/x
no shut
Kind Regards
Paul
It is not clear what is going on here. A good starting point would be to post the output of show interface from both routers.
Rick
Will post it tomorrow
Here you have copied effects of show interface command on both routers
  Hardware is AmdP2, address is 000a.41d5.5fa0 (bia 000a.41d5.5fa0)
  Description: siec lokalna 192.168.1.0
  Internet address is 192.168.1.1/24
     reliability 168/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Last input never, output 00:00:02, output hang never
  Queueing strategy: fifo
  Output queue :0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     54 packets output, 3528 bytes, 0 underruns
     54 output errors, 0 collisions, 2 interface resets
     54 lost carrier, 0 no carrier
  Last input never, output 00:00:05, output hang never
     56 packets output, 3665 bytes, 0 underruns
     56 output errors, 0 collisions, 2 interface resets
     56 lost carrier, 0 no carrier
     0 watchdog
     42 packets output, 3396 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     42 lost carrier, 0 no carrier
FastEthernet0/1 is administratively down, line protocol is down
  Hardware is AmdFE, address is 000a.b783.a481 (bia 000a.b783.a481)
  Description: siec lokalna 192.168.8.0
  Internet address is 192.168.8.1/24
  Last input never, output never, output hang never
     0 watchdog
     0 packets output, 0 bytes, 0 underruns
     0 lost carrier, 0 no carrier
It is an interesting observation about the difference in speed. I am more concerned about this aspect of the situation
You could try setting the speed to 10MB (which will prevent negotiation of duplex, resulting in using half duplex) and see if it resolves the issue. I am not optimistic about that. I would suggest trying a different cable for the connection. And perhaps making sure that the cable connects Ethernet0/1 to FastEthernet0/0.
Rick
mlund
Level 7
Level 7
I'm pretty shure that the problem is speed mismatch.
In routers even today (nexus excluded) the name of the interface specify the maximum speed an interface can have.
Ethernet means 10M, and can't be higher
FastEthernet means 100M, and can often be lowered to 10M with configuration or auto (not if it is fiber connection).
A 10M can't talk to 100M due to different coding on the wires. Although an 100M can often detect that there is an 10M device connected and lower it's speed.
/Mikael
witek77
Hello guys,
There wa some kind of a problem with witek 2600 router. I’ve replaced it with a 1700 series one with one FastEthernet port with auto speed and auto-duplex option build in. It works ok, ping gets trough so thank you very much. I changed the cable before and also tried different kind of duplex on both routers but it didn’t work out so as you have advised me  I figured out there must be a problem with port in one of the routers. Now the reliability is 255/255 on both of the routers and ping gets trough so I guess it’s ok. Thank you very much. It’s my first small success in connecting two routers together and configurating it.
But I also have a question. I connected laptop computer to the other Ethernet port on bartek 2600 series router. Ping gets trough from the Ethernet port on laptop to the Ethernet port on the 2600 router but only to this one which is connected to and not the one which connects two routers together and of course it doesn’t get trough to the other router. Same the other way round. Could you please tell me what can be a reason behind it?
I established ip address on Ethernet port on laptop to 192.168.1.100 and 2600 series router interface it is connected to has an address 192.168.1.1
can you post the configurations (sh run) of both routers ?
startup-config for 1700
adam2#show startup-config
Using 1108 out of 29688 bytes
! Last configuration change at 00:20:09 UTC Fri Mar 1 2002
! NVRAM config last updated at 00:20:35 UTC Fri Mar 1 2002
version 12.3
hostname adam2
boot-start-marker
boot-end-marker
enable secret 5 $1$QkyI$voMKVJu.dYIPq4BSEc4wn0
enable password router2
no aaa new-model
ip subnet-zero
no ip routing
no ip cef
ip audit notify log
ip audit po max-events 100
ip ssh break-string
no ftp-server write-enable
no scripting tcl init
no scripting tcl encdir
no crypto isakmp enable
interface FastEthernet0
 description siec pomiedzy routerami 192.168.2.0
 ip address 192.168.2.1 255.255.255.0
 no ip route-cache
 speed auto
interface Serial0
 description polaczenie pomiedzy routerami
 no ip address
 no ip route-cache
 shutdown
 clockrate 4000000
ip classless
no ip http server
no ip http secure-server
control-plane
line con 0
 password adam_con
 logging synchronous
 login
line aux 0
line vty 0 4
 password adam_vty
 logging synchronous
 login
end
startup-config for 2600
bartek#show startup-config
Using 1227 out of 29688 bytes
version 12.2
service password-encryption
hostname bartek
enable secret 5 $1$e3y1$mP5ucOkByHS6hutqhD.BA/
enable password 7 0316541E120A331E
ip subnet-zero
no ip routing
interface Ethernet0/0
 description siec lokalna 192.168.1.0
 no ip route-cache
 no ip mroute-cache
 half-duplex
 no mop enabled
interface BRI0/0
 no ip address
 no ip route-cache
 no ip mroute-cache
 shutdown
interface Serial0/0
 no ip address
 no ip route-cache
 no ip mroute-cache
 shutdown
 no fair-queue
interface Ethernet0/1
 description SIEC LOKALNA 192.168.2.0
 ip address 192.168.2.2 255.255.255.0
 no ip route-cache
 no ip mroute-cache
 half-duplex
ip classless
ip http server
banner exec ^C
JESTEM BANNER exec POJAWIAM SIE PRZED LOGOWANIEM DO TRYBU UPRZYWILEJOWANEGO ^C
banner login ^C
WITAM JESTEM BANNER login I POJAWIAM SIE PO motd LECZ PRZED LOGOWANIEM ^C
banner motd ^C
Uwaga!!!
Logujsz sie na router. Wszystkie czynnosci sa rejestrowane. ^C
line con 0
 exec-timeout 60 0
 password 7 01120205563405002F
 logging synchronous
 login
line aux 0
line vty 0 4
 password 7 111B16100317195F
 login
end
on both routers, you need to enable 'ip routing':
Router#conf t
Router(config)#ip routing
Thanks a lot. It works now perfectly. I've been capable of checking the ip routes of both routers and adding to 1700 series one the route connecting 2600 router to the laptop computer which is 192.168.1.0. I still have a problem with getting ping trough from 1700 to laptop but it may just be because I've thought the two different kind of hardware supposed to be connected trough normal cable and  I have just read trough that I am supposed use a cross-over cable on Ethernet interface connection like this as well. We'll see.
Thanks for the additional information. Glad to know that adding ip routing has solved most of the problem.
When connecting a router to a laptop whether it can be done with normal Ethernet cable or needs a cross over cable depends on the model of router (and perhaps version of code that it is running). For newer routers it frequently is possible to use regular Ethernet cable. For routers that are older, like yours are, it is normal to need cross over cable.
Rick
I've changed the cables. I've also read an article called "how to allow pings ICMP Echo Requests through your Windows Firewall", produced 2 new rules allowing Incoming ICMPv4 and ICMPv6 Echo Requests. So now I can send ping from a distant router 1700 through the 2600 router to laptop and it gets through but the other way round it doesn't. I've thought maybe similar rule regarding outbound traffic will do the trick, so I made 2 additional rules regarding allowing outgoing Echo Requests  both for ICMPv4 and ICMPv6 but no luck, ping from laptop to the 1700 router doesn't get through. Maybe you can help me with that one as well?Regards                              Witek
