no upload speed in ISP
nitish14351
Hii,
We are facing some issue with our ISP. we have 150 mpbs ISP link, there download speed is there, but we have 0% upload speed. Unable to find the reason for this.
We are using cisco ISR4451-X/K9 router.
The configuration of router interface in below:-
interface GigabitEthernet0/0/2 (WAN interface)
 description ## 150 Mbps Mbps Internet Link from BSNL and circuit ID 1000303162 ##
 bandwidth 153600
 ip address 172.24.177.217 255.255.255.252    (ISP IP)
 ip nat outside
 load-interval 30
 negotiation auto
 performance monitor context PrmAM_AVP4_c
 service-policy output parent-policy
interface GigabitEthernet0/0/3 (inside interface)
 ip address a.b.c.d 255.255.255.224
 ip nat inside
 ip tcp adjust-mss 1460
 negotiation auto
Kindly suggest something
8 Replies 8
post the full configuration of your router...
Hii Georg,
please find conf in attachment.
Thanks in advance
the configuration looks ok, although I am not sure I understand your IP addressing - are these all public addresses ?
Either way, on your inside interface, remove 'ip tcp adjust-mss 1460':
ip nat inside
--> no ip tcp adjust-mss 1460
negotiation auto
Also, post the output of:
show interfaces GigabitEthernet0/0/2
show interfaces GigabitEthernet0/0/3
Hiiiii ,
After removing that command, still issue is there. And also find the output you asked for.
try and remove the service policy from the interface
bandwidth 153600
ip nat outside
load-interval 30
negotiation auto
--> no service-policy output parent-policy
and use a site like
http://www.speedtest.net/
from one of your clients to check what speeds you are getting...
I have already tried that still i am not getting upload speed. Also in mnetion site www.speedtest.net , zero upload still.
i am unable to find the issue.
Kindly help.
Thanks in advance.
it sounds like the problem could be with the provider...have you checked with them ? They can test down and up speeds from their side as well...
Hiii,
I have logged the complaint with my ISP, but still waiting for their customer.
Still meanwhile I am checking that issue is not is router configuration.
If you find anything wrong my configuration, let my know.
