No Voice commands on cisco router
davidrichard3
I cannot find voice commands on my router, I have licenced it but no voice commands or sip are found
Its on packet tracer. gzolehana
Cisco router 2911
Thank you
7 Replies 7
pman
You may want to try working according to the following guide:
https://www.packettracernetwork.com/tutorials/voipconfiguration.html
Ladlamuzamil
Do you have any VoIP hardware installed on the router?
in Packet Tracer, you need the 2811 router, which has all the voice commands:
Router(config)#?
Configure commands:
aaa Authentication, Authorization and Accounting.
access-list Add an access list entry
banner Define a login banner
bba-group Configure BBA Group
boot Modify system boot parameters
cdp Global CDP configuration subcommands
class-map Configure Class Map
clock Configure time-of-day clock
config-register Define the configuration register
crypto Encryption module
default Set a command to its defaults
dial-peer Dial Map (Peer) configuration commands
do To run exec commands in config mode
dot11 IEEE 802.11 config commands
enable Modify enable password parameters
end Exit from configure mode
ephone define ethernet phone
ephone-dn Configure ephone phone lines (Directory Numbers)
exit Exit from configure mode
flow Global Flow configuration subcommands
hostname Set system's network name
interface Select an interface to configure
ip Global IP configuration subcommands
ipv6 Global IPv6 configuration commands
key Key management
line Configure a terminal line
lldp Global LLDP configuration subcommands
logging Modify message logging facilities
login Enable secure login checking
mac-address-table Configure the MAC address table
no Negate a command or set its defaults
ntp Configure NTP
parameter-map parameter map
parser Configure parser
policy-map Configure QoS Policy Map
port-channel EtherChannel configuration
priority-list Build a priority list
privilege Command privilege parameters
queue-list Build a custom queue list
radius-server Modify Radius query parameters
router Enable a routing process
secure Secure image and configuration archival commands
security Infra Security CLIs
service Modify use of network based services
snmp-server Modify SNMP engine parameters
spanning-tree Spanning Tree Subsystem
tacacs-server Modify TACACS query parameters
telephony-service Configure Cisco Unified Communications Manager Express
username Establish User Name Authentication
vpdn Virtual Private Dialup Network
vpdn-group VPDN group configuration
zone FW with zoning
zone-pair Zone pair command
Router(config)#
SajjalCol
Have you reloaded since enabling the voice license? It's also possible PT simply doesn't support voice. Best Badminton Shoes
PopularThemeReview
just FYI, the only router in Packet Tracer that currently supports voice is the 2811 (see my post above). You cannot install any additional licenses, it is just a simulation software.
machinecraf
I am running into is being capable of ping from the Host laptop on the 192.168.One zero five.X network to any interior interfaces. Of which i can not get ASDM setup except i put myself on the management IP range that the ASA is setup on. I ran a packet-tracer and it looks as if its coming down to an get entry to listing that isn't configured for different types.
do you have a Packet Tracer project (.pkt) file ? If so, ZIP it and post it here...
