Non-transitive MED in BGP path selection
Leftz
Level 4
Level 4
Hello, Please see below diagram. R4 send route 10.4.0.0 to R1 with MED 100. R1 can see the route with MED. MED is non transitive attribute. Why it happens? The diagram is from the link below. Thanks
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13759-37.html
because R1,R2 & R3 same AS (65501), i.e. all router iBGP and MED is forward between router in same AS.
but if we connect another router to R1 and with different AS then the MED will not forward to new router because of MED non transitive.
for you to understand MED, the MED can pass only one AS no more.
8 Replies 8
I am also confuse first time read about MED
there are two metric
one is MED
in example below MED is 100
other is IGP metric to
next-hop
in example below it is 74
  192.168.30.4 (metric 74) from 3.3.3.3 (3.3.3.3)
      Origin IGP, metric 100, localpref 100, valid, internal, best
 so try change the Cost between two router you will see that IGP metric will change.
Leftz
Level 4
Level 4
Thanks. I have the question when I review the document(see link). why R1 can see route 10.4.0.0 with MED 100, as the document discussed. MED is non transitive, why R1 can see the MED when R4 send MED to R1?
I am not sure my understanding is correct. Anyone can have some comment on this?
Please see the below which is from the document
R1 now sees the route over R2 as the best path for network 10.4.0.0/16 because the update received from R2 has a MED of 100 versus a MED of 200, which is what R3 advertises. Similarly, R1 uses R3 and the R3 - R4 link to access 10.5.0.0/16:
r1# show ip bgp 10.4.0.1
BGP routing table entry for 10.4.0.0/16, version 14
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Flag: 0x800
  Not advertised to any peer
  65502
    192.168.20.4 (metric 128) from 2.2.2.2 (2.2.2.2)
r1#sh ip bgp 10.5.0.1
BGP routing table entry for 10.5.0.0/16, version 13
Flag: 0x800
  65502
    192.168.30.4 (metric 128) from 3.3.3.3 (3.3.3.3)
""When a BGP speaker learns a route from a peer, the route's MED is passed to other interior BGP (iBGP) peers, but not to exterior BGP (eBGP) peers.""
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/112965-bgpmed-attr-00.html
Leftz
Level 4
Level 4
R4's as is 65502 and R4 is exterior(eBGP) to R1, R2, and R3 whose as is 65501. why the MED can go through R2 and R3 to R1?
small Lab
R1 have LO 1.1.1.1/32 and I use route-map to make MED = 1000
in R3 we see the MED is 1000 because R2 and R3 in same AS so the R2 forward MED value to R3
Now the Lo is forward to R4 different AS but you see MED is empty becuase the R3 not forward MED value out it AS.
rais
Level 7
Level 7
Per RFC-4271:
the MULTI_EXIT_DISC attribute MAY be propagated over IBGP to
   other BGP speakers within the same AS (see also 9.1.2.2).  The
   MULTI_EXIT_DISC attribute received from a neighboring AS MUST NOT be
   propagated to other neighboring ASes.
Leftz
Level 4
Level 4
Great! Thanks @MHM Cisco World
Point is that MED can be passed to ebgp, but only one time. otherwise how it can work
