not able to configure atm interface
t4tauseef33
Hi, I have 2811 router with IOS
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(3i), RELEASE SOFTWARE (fc2)
I have installed 2X 1SHSDL-V3 cards into that. When configuring the SDSL card, i found that the int atm 0 command is not working. Can you please help me how can i have the interface atm on my router. Is any other command is needed to enable the atm interface?
Router-01(config)#int ?
Async Async interface
BVI Bridge-Group Virtual Interface
CDMA-Ix CDMA Ix interface
CTunnel CTunnel interface
Dialer Dialer interface
FastEthernet FastEthernet IEEE 802.3
Group-Async Async Group interface
Lex Lex interface
Loopback Loopback interface
MFR Multilink Frame Relay bundle interface
Multilink Multilink-group interface
Null Null interface
Port-channel Ethernet Channel of interfaces
Tunnel Tunnel interface
Vif PGM Multicast Host interface
Virtual-PPP Virtual PPP interface
Virtual-Template Virtual Template interface
Virtual-TokenRing Virtual TokenRing
range interface range command
paolo bevilacqua
Hi, you need IOS 12.4(5) and above for hwic-shdsl-v3.
