06-08-2017
04:22 AM
- last edited on
03-05-2019
08:40 AM
by
NikolaIvanov
hi every one,
I have a 1941 router with gig 0/0 configured to act as pppoe wan, through which dialer 1 interface connects to the isp. The pppoe connection is up and and has an IP address (gained through negotiation). The problem is that I can't telnet to IP address of the dialer 1 interface from remote network and unfortunately telnet connection times out, although without any problem from within the local lan of gig 0/0 and to that same IP address of dialer 1. here is what I have already tried :
1- I have changed mtu and mss of the dialer interface
2- set access-list any with log enabled on line vty which logs just telnet connections to gig 0/0 IP address but not dialer IP address (It means connection does not reach to the router.
3- I activated "ip nat inside static" on dialer 1 as output and gig 0/1 as input interface but with no result so cleared the config.
4- I am sure telnet is not blocked by the isp
thank everybody in advance.
By the way here is my configuration:
Router#show run
Building configuration...
Current configuration : 1820 bytes
! Last configuration change at 11:11:08 UTC Thu Jun 8 2017
version 15.6
hostname Router
boot-start-marker
boot system flash:c1900-universalk9-mz.SPA.156-3.M1.bin
boot-end-marker
logging buffered 16000
enable secret 5 $1$am..$3LBECeZtyF7lHQgr.vXEL0
no aaa new-model
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FCZ1430927H
username psp password 0 12321
redundancy
ip tcp ecn
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description PPPoE-Shatel
ip address 192.168.88.211 255.255.255.0
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface GigabitEthernet0/1
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
interface Dialer1
mtu 1404
ip address negotiated previous
ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1380
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username xxxxxxx password 0 xxxxxx
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer1
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
dialer-list 1 protocol ip permit
access-list 2 permit any log
control-plane
line con 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 2 in
password 12321
login local
transport input all
scheduler allocate 20000 1000
end
06-08-2017 06:37 AM
Do you want telnet to manage the device?
Try configuring
line vty 0 4
login local
06-08-2017 06:41 AM
thanks for your reply Julio but as you can see I have set the same config on line vty:
line vty 0 4
access-class 2 in
password 12321
login local
transport input all
06-08-2017 06:42 AM
Hello
Your Dialier interface is set to negotiate an address from the ISP via the same physical interface that has a static address applied.
Try removing this static address and renegotiated a ISP addressing and then test telnet again against the newly received addressing and not the present static assign address
res
Paul
06-08-2017 06:45 AM
I have already test that with no success. Besides the show ip interface brief, shows a valid ip on dialer 1 which can be easily pinged. Even I can open http page of the router if i were enabled.
06-08-2017 07:59 AM
Hello
To confirm you have remove the static ip address of the physical interface and you can ping the allocate ip address of the dialer interface but cannot telnet to it?
can you perform some debugging please and post the results on the failing ip address of the Dialer1 interface ip.
access-list 100 permit tcp host any any eq telnet log
debug condition interface Dialer1
debug ip packet detail 100
res
Paul
06-08-2017 09:06 AM
The situation is as what you've got, besides I can ping the negotiated IP from the same segment Net as wan port (gig 0/0).
I'll post the result of the intstructions you mentioned as soon as possible.
And I apperitiate your help.
06-08-2017 11:08 AM
Hello
forgot to ask - without NAT you say Your internal network is able to reach the internet?
So I am assuming your isp are doing this for you?
res
Paul
06-08-2017 10:48 PM
No I could ping internet from within the router without NAT, though I setup NAT for the local LAN to access the Internet and again telnet was not possible to the router remotely.
06-09-2017 01:14 AM
Hello
Okay so to be able to remote access into your network (via the wan) then you'll need NAT as the addressing you shown isn't routable so it wont be reachable.
However this should not prohibit you to remote access to the rtr if the rtr its self is receiving a public routable address from the isp,
Can you confirm you are receiving a public ip and not a Private one as you have posted.in your OP
res
Paul
06-09-2017 11:06 PM
Hi, Paul
after executing the commands you mentioned above I figured out that no packet is being received in the router and telnet port is blocked by the ISP though they had already denied that but after more investigation they confirmed that. All this days I was looking for black been.
After all I appreciate your help to others and thank you.
06-10-2017 02:45 AM
Hello
great news - Having prove in the form of some debug or logging can come out n very handy
glad i have been of some help
res
paul
06-10-2017 04:03 AM
I changed telnet port to 7034 and now I can telnet to my router. here is the config:
access-list 120 permit tcp any any eq 7034
line vty 0 4
access-class 120 in
privilege level 15
login local
rotary 34
transport input telnet ssh
just as reference for others rotary adds 7000 to the number set in the command (7000 + 34 = 7034).
06-10-2017 07:53 AM
Hello
cheers for the rating- FYI I use rotary quite a lot as a backdoor when using ttacacs and there is a need to access for someone who doesn't have tacacs account
res
paul
