07-19-2011 08:45 PM - edited 03-04-2019 01:02 PM
I have a EIGRP route which get redistributed into bgp andhas to be advertised to MPLS cloud. this is what i am seeing. BGP keep saying not advertised to any peer. Can anyone throw some light ?
Next hop is reachable, this is the only valid and best path...
xxxxxxxxxxx>sh ip route 10.70.8.1
Routing entry for 10.70.8.0/29
Known via "eigrp 555", distance 90, metric 52802816, type internal
Redistributing via bgp 65494, eigrp 555
Advertised by bgp 65494 route-map EIGRP-to-BGP
Last update from 10.66.246.253 on GigabitEthernet0/0, 00:00:00 ago
Routing Descriptor Blocks:
* 10.66.246.253, from 10.66.246.253, 00:00:00 ago, via GigabitEthernet0/0
Route metric is 52802816, traffic share count is 1
Total delay is 500110 microseconds, minimum bandwidth is 64 Kbit
Reliability 255/255, minimum MTU 1440 bytes
Loading 1/255, Hops 2
xxxxxxxx>sh ip bgp 10.70.8.1
BGP routing table entry for 10.70.8.0/29, version 489127
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Flag: 0x820
Not advertised to any peer
Local
10.66.246.253 from 0.0.0.0 (128.212.44.210)
Origin incomplete, metric 52802816, localpref 100, weight 32768, valid, sourced, best
07-22-2011 11:38 AM
Can you please share following outputs?
show ver | in IOS
show run | sec router bgp
show ip prot
show ip bgp nei x.x.x.x adv | in 10.70.8.0 <<<< to make sure that this is actually happening.
07-23-2011 01:37 AM
how does the route-map EIGRP-to-BGP look like?
HTH,
Milan
