1600 byte mtu for DSL?
lcaruso
Level 6
Level 6
This is my first experience with an 887VA router. I was surprised to see the ATM mtu is 1600.
Is there anything I can do to speed this router's DSL performance? It is slower than an off the shelf ActionTec costing less than $100.
I've already updated the firmware to the latest release. Same with IOS.
dslrouter#sh controller vdsl 0
Controller VDSL 0 is UP
Daemon Status:           Up
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'GSPN'
Chip Vendor Specific:   0x0000                   0x000D
Chip Vendor Country:    0xB500                   0xFFB5
Modem Vendor ID:        'CSCO'                   '    '
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0x0000
Serial Number Near:    FTX151902CJ 887VA-SE 15.1(4)M
Serial Number Far:
Modem Version Near:    15.1(4)M
Modem Version Far:     0x000d
Modem Status:            TC Sync (Showtime!)
DSL Config Mode:         AUTO
Trained Mode:            G.992.5 (ADSL2+) Annex A
TC Mode:                 ATM
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Trellis:                 ON                       ON
Line Attenuation:         9.5 dB                  2.3 dB
Signal Attenuation:       9.5 dB                 43.8 dB
Noise Margin:            11.1 dB                 14.0 dB
Attainable Rate:        20728 kbits/s            28740 kbits/s
Actual Power:             dBm             7.6 dBm
Total FECS:             0                        0
Total ES:               0                        0
Total SES:              0                        0
Total LOSS:             0                        0
Total UAS:              0                        0
Total LPRS:             0                        0
Total LOFS:             0                        0
Total LOLS:             0                        0
Bit swap:               0                        18
Full inits:             1
Failed full inits:      0
Short inits:            0
Failed short inits:     0
Firmware        Source          File Name (version)
VDSL            default         flash:vdsl.bin (10)
Modem FW  Version:      110201_1505-4.02L.03.A2pv6C033c.d23e
Modem PHY Version:      A2pv6C033c.d23e
                  DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             0            14975             0               766
Previous Speed:           0                0             0                 0
Total Cells:              0         37649525             0           1886643
User Cells:               0           510515             0             85265
Reed-Solomon EC:          0                0             0                 0
CRC Errors:               0                0             0                 0
Header Errors:            0                0             0                 0
Interleave (ms):       0.00             3.94          0.00              2.31
Actual INP:            0.00             0.51          0.00              0.57
Training Log :  Stopped
Training Log Filename : flash:vdsllog.bin
dslrouter#sh int
ATM0 is up, line protocol is up
  Hardware is MPC ATMSAR, address is a.b.c (bia 503d.e574.b444)
  MTU 1600 bytes, sub MTU 1600, BW 766 Kbit/sec, DLY 480 usec,
     reliability 255/255, txload 14/255, rxload 101/255
  Encapsulation ATM, loopback not set
  Keepalive not supported
  Encapsulation(s): AAL5
  4 maximum active VCs, 1024 VCs per VP, 1 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input 00:12:29, output 00:00:01, output hang never
  Queueing strategy: Per VC Queueing
  5 minute input rate 304000 bits/sec, 21 packets/sec
  5 minute output rate 45000 bits/sec, 10 packets/sec
     18773 packets input, 23530615 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     14193 packets output, 3635602 bytes, 0 underruns
     0 unknown protocol drops
ATM0.1 is up, line protocol is up
  Hardware is MPC ATMSAR, address is a.b.c (bia a.b.c)
  MTU 1600 bytes, BW 766 Kbit/sec, DLY 480 usec,
  Encapsulation ATM
     18773 packets input, 23718261 bytes
     0 OAM cells input, 0 OAM cells output
  AAL5 CRC errors : 0
  AAL5 SAR Timeouts : 0
  AAL5 Oversized SDUs : 0
BVI1 is up, line protocol is up
  Hardware is BVI, address is a.b.c (bia 0000.0000.0000)
  Description: TDS
  Internet address is a.b.c.d/30
  MTU 1600 bytes, BW 4608 Kbit/sec, DLY 5000 usec,
     reliability 255/255, txload 2/255, rxload 17/255
  Keepalive set (10 sec)
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 310000 bits/sec, 21 packets/sec
  5 minute output rate 42000 bits/sec, 10 packets/sec
     18766 packets input, 23792529 bytes, 0 no buffer
     13821 packets output, 3481612 bytes, 0 underruns
5 Accepted Solutions
paolo bevilacqua
Possibly, you have firewall, inspection, cbac, and other unnecessary configurations.
If so, remove them and test again.
Also, you can try RBE (atm route-bridged ip) instead of BVI/IRB.
RBE works fine for CPE, it's worth to try it.
Just remove ip virtual-reassembly.
Can you post a numeric comparison of speedtest.net, between Cisco and the other router ?
There is a difference, albeit not large. (to easily copy speedtest.net results to clipbpard, click "my results" and select the line(s) of interest).
The problem maybe has something to do with interleave or other suble ADSL detail. Usually Cisco can fixes this kind of stuff, but it takes time.  If you have a support contract, you can insist that your problem is given  to engineering, as you can demonstrate how a competitor product performs better.
RBE is very simple, under subif remove bridge, place ip address, and "atm route-bridged ip". Also remove virtual reassembly.
Please remember to rate useful posts clicking on the stars below.
Unfortunately a clean configuration doesn't always mean better performances, but at least you've tried what is in your power.
It would be interesting to know if the other router uses interleaving. Supposedly it should have to, as interleaving is controlled by the DSLAM. See: http://www.kitz.co.uk/adsl/interleaving.htm
Thanks for the nice rating and good luck!
No, it will forward forward fragments. It is supposedly done to help consistency of ACL, NAT and so.
But all works better without it.
10 Replies 10
paolo bevilacqua
I was told by TAC that RBE is not for CPE. Are they right?
I don't have much of a configuration that would slow things down, as I do know what you mean.
Thanks for the tip on RBE! I'll try it.
Do you have an example of RBE for RFC 1483  bridged?
I have speedtest.net results, but I find them somewhat erratic. My best metric is ping.
When I ping the next hop router across my DSL connection, the TDS-branded ActionTec724R performs a consistent 7ms faster. ActionTec 11ms consistent average. 887VA 18ms consistent average.
TDS uses an Entrisphere DSLAM, don't know which model. I can only assume they tweaked the BIOS on their branded modem to work a little better with their DSLAM.
I wonder if there are any tweaks I could make on the 887VA besides trying RBE?
RBE works, so you are correct--thank you!
It was surprising though, given how much cleaner RBE is, that my speeds didn't really increase appreciably.
Thanks for the tips about engineering and such. You are a great contributer to these forums.
Thanks for the link. Looks like a good site.
Was removing ip virtual-reassembly just for the ATM0.1 subinterface and/or for all interfaces on the router? Does this mean the router will drop fragmented packets?
