NTP Control Queries
Bilal Al-Sardar
Hello Team!,
I would like to know if it is possible to disable NTP control queries on Catalyst switches and ISR routers.
11 Replies 11
balaji.bandi
what is the use case here - as i read part of my cert journey  INE have good blog :
https://ine.com/blog/2008-07-28-ntp-access-control
BB
NTP is already configured with multiple server IPs associated with a key and MD5 authentication. we had a security assessment and we received a report that recommends disabling "NTP control queries". I have tried to use an ACL but that caused an "unsynchronised" status.
Without config ntp server and ntp peer
SW or ISR not send any queries.
NTP is already configured with multiple servers.
what i am thinking,
If you have ACL which source and destination for NTP traffil allowed, that should be ok
BB
Tried this method, but i keep getting (unsynchronized) status.
I think alot
There are two ways I think
1- config acl with query-only
This send ntp control for only server list in acl
2- change the mode to ntp broadcast' which is as silent mode in which server send ntp messages without any ntp from client/peer
Tried this method, but it keeps getting (unsynchronized) status.
Which one you try
Acl with query only OR broadcast?
ACL only. Broadcast is not allowed in the environment.
M02@rt37
Hello @Bilal Al-Sardar,
do not config NTP on your equipement !
Best regards
