01-27-2010 01:20 PM - edited 03-04-2019 07:19 AM
I am trying to enable NTP as the source for the loopback interface and when I set the command "ntp source Loopback0" the router says the following:
Router(config)#ntp source Loopback0
ntpio_set_global_source failed
Router(config)#
Jan 27 21:19:24.471 UTC: ntpio_set_global_source: not an NTP interface.
Any ideas on why this can't be done.
Solved! Go to Solution.
01-27-2010 02:02 PM
What is the version of your IOS?
Try the following command: ntp server A.B.C.D source loop0 {prefer}
01-27-2010 02:02 PM
