Null0 statistics or hit counts
wherewolf
Cisco ASR  1001x  Cisco IOS XE Software, Version 17.03.05
I have implemented BGP peering with Team-Cymru for ipv4 and ipv6 bogons. The routes from this peering are community-matched for "next hop" to either 192.0.2.1 or 100::/64 - both of which have a static route to Null0 - this all seems to be working perfectly, and is a big improvement over massive ACL's that need to be updated frequently to perform the same type of filtering.
However the ACL's would allow me to see hits / matches -   with the new peering, I can't see any details - when I show int Null0,  it shows the interface up, but all stats are zero's
Is there some special method to show hit counts, stats or traffic numbers for packets being routed to Null0?
8 Replies 8
I config static route toward null0 in R2 and advertise the static route toward null0 to R1
then I ping R1 to R2 (static route IP)
then check the null0 I see the packet output count is increase.
what you see I think that you use static route null0 as aggregate route, and when packet hit router the router do longest match
and since there is route with subnet mask better than null0 static route subnet mask the router will use the longest match and null0 interface count not count.
Thank you for try to help me understand.  "since there is route with subnet mask better than static route subnet mask the router will use the longest match"    I'm not sure I'm understanding this in my case.  (I'm still learning - I've only been working with edge routing in the past couple of months.)  And I do understand that IPv4 bogons/martians are fairly limited these days, but I'm also doing this on the IPV6 side, so the knowledge and practice is good.)
Show run:
ip route 192.0.2.1 255.255.255.255 Null0
ip community-list 100 permit 65332:888
route-map BOGONS-V4-IN permit 10
 description IPv4 bogons
 match community 100
 set ip next-hop 192.0.2.1
#show ip route 100.64.0.1
Routing entry for 100.64.0.0/10
  Known via "bgp 17218", distance 20, metric 0
  Tag 65332, type external
  Last update from 192.0.2.1 5d05h ago
  Routing Descriptor Blocks:
  * 192.0.2.1, from 38.229.50.81, 5d05h ago
      opaque_ptr 0x7F3EA4E32A18
      Route metric is 0, traffic share count is 1
      AS Hops 1
      Route tag 65332
      MPLS label: none
#show bgp ipv4 unicast  100.64.0.1
BGP routing table entry for 100.64.0.0/10, version 22997010
Paths: (2 available, best #2, table default, not advertised to EBGP peer)
Multipath: eBGP
  Not advertised to any peer
  Refresh Epoch 1
  65332, (received & used)
    192.0.2.1 from 38.229.60.81 (38.229.60.81)
      Origin IGP, localpref 100, valid, external
      Community: 65332:888 no-export
      rx pathid: 0, tx pathid: 0
      Updated on Jan 27 2023 04:40:10 PST
  Refresh Epoch 1
    192.0.2.1 from 38.229.50.81 (38.229.50.81)
      Origin IGP, localpref 100, valid, external, best
      rx pathid: 0, tx pathid: 0x0
      Updated on Jan 27 2023 04:39:59 PST
#ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 23/23/23 ms
#ping 100.64.0.1
Sending 5, 100-byte ICMP Echos to 100.64.0.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
#show int null0
Null0 is up, line protocol is up
  Hardware is Unknown
  MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 0 usec,
     reliability 0/255, txload 0/255, rxload 0/255
  Keepalive set (10 sec)
  Last input never, output 5d02h, output hang never
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     Output 0 broadcasts (0 IP multicasts)
     0 unknown protocol drops
https://www.senki.org/operators-security-toolkit/remote-triggered-black-hole-rtbh-filtering/
you use next-hop toward null0 is RTBH BGP security, check the link above for more detail about this BGP security
Thank you for this link - this is very informative.
It's my understanding that anytime you invoke BGP, a null0 interface is created on a Cisco ASR, even though it is not explicitly defined.
That brings up my next question on this:
#show run int null0
Building configuration...
Current configuration : 5 bytes
end
I never defined Null0,  it already existed.
Since it already exists,  if I add routes as in the example given (using my route) will that break things?    In my case, these are production routers - I don't want to send things into oblivion.
(in testing, I cannot add "routes" directly to the interface as shown in the article)
https://community.cisco.com/t5/routing/bgp-flowspec-and-rtbh/m-p/4676084
I explain the RTBH in this post, please take look
I have read articles about RTBH, but generally it's coordination with your ISP to give you a way to redirect your outbound advertisement of an ip range / address (space you advertise) to a black-hole of the ISP, to prevent/mitigate DDOS on the inbound side of your router.   I can wrap my head around that.
In my case,  I'm using this same technique to route traffic to / from a list of potential bad actors (ip addresses or ip ranges - inbound or outbound) to a null route.    This technique seems to be working correctly - with much less trouble than building unmanageable ALC's for the edge routers - it's just a matter of not being able to see stats or dropped traffic in order to monitor the efficacy.
 it's just a matter of not being able to see stats or dropped traffic in order to monitor the efficacy.    <<-
I will do deep dive find a way you can real time see the packet drop by null 0.
I will update you soon
thanks
Thank you so much for your help.   There is so much to learn,  and so much documentation - some of which may or may not apply depending on the platform and release etc.....
I did find this:
show platform hardware qfp active statistics drop
 but I'm not sure how I can pull it from the ASR with solarwinds in order to graph it, record it, or even display it without actually logging into the asr (both of them - since they are both active) to display the numbers.
