NX5K NX-OS Upgrade
zekebashi
Level 4
Level 4
We have a couple of NX5Ks(5010s) with NX-OS 5.0(3)N2(1) and we need to upgrade them to the one of the higher releases. I did some research and found out that there are a number of releases after this outdated release(5.0(3)N2(1). There's a series of releases in the 5.1 train: 5.1(3)N2(1), 5.1(3)N2(1a), 5.1(3)N2(1b), 5.1(3)N2(1c). Also, there is several releases in the 5.2 train: 5.2(1)N1(1), 5.2(1)N1(1a), 5.2(1)N1(1b), 5.2(1)N1(2), 5.2(1)N1(2a).....etc.
My question is, do I need to sequentially upgrade from 5.0(3)N2(1) to 5.1(3)N2(1), 5.1(3)N2(1a), 5.1(3)N2(1b), 5.1(3)N2(1c) and then to the 5.2(1)N1(1), 5.2(1)N1(1a), 5.2(1)N1(1b), 5.2(1)N1(2), 5.2(1)N1(2a).....etc.  or can I leap-frog from the 5.0(3)N2(1) to release 5.1(3)N2(1) and then to 5.2(1)N1(9)?
Thanks in advance,
~zK
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/release/notes/Rel_5_1_3_N2_1/Nexus5000_Release_Notes_5_1_3_N2.html
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/release/notes/Rel_5_2_1_N1_1/Nexus5000_Release_Notes_5_2_1_N1.html
chrihussey
Hello, the way it looks to me you should be able to upgrade directly to 5.2(1)N1(9). Check the second note in Table 5. If unsure it would be wise to open a CCO case to verify.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/release/notes/Rel_5_2_1_N1_1/Nexus5000_Release_Notes_5_2_1_N1.html#pgfId-284956
Thanks for your reply. That's what I am thinking. According to the matrix, I should be able to upgrade directly to release 5.2(1)N1(9). Good advice. I will go ahead and contact CCO to make sure.
Thanks, ~zK
