Object Tracking in Nexus 7000 Platform
3alee
Hello
I'm going to replace a Cat6513 with a Nexus 7018.  In my Cat6513, there are object tracking config as follows:
ip sla monitor 1
type echo protocol ipIcmpEcho 112.78.254.249
timeout 3000
frequency 6
ip sla monitor schedule 1 life forever start-time now
ip route 172.17.7.0 255.255.255.0 165.202.51.46 name VPN-1 track 123
Is there similar feature in Nexus platform?  Because from Nx-OS command ref, I only found:
ip route ip-prefix/mask {[interface] next-hop} [preference] [tag id]
Seems can't associate a track object to a static route in Nx-OS??
Thanks.
5 Replies 5
nkarpysh
IP-SLA support on the Nexus 7000 with sender/responder functionality and most common
probes are planned for the Freetown release 6.2 . I think that is expected in summer 2012.
Hope this helps,
Nik
HTH,
Niko
Thanks very much!
No Problem,
You can rate if was helpful for it to be useful in future.
Nik
HTH,
Niko
aldunn
Hmm, now on version 5.2(7) and still no sign of object tracking in this code.
jkilleda
Level 3
Level 3
Hello ADRIAN KAM,
CLI for object tracking in catalyst switch differs from CLI of NX-OS , for configuring object tracking in NX-OS make sure that you are in correct VDC.
