Odd But Consistent Packet Dropping
frank.trampe
I have a Cisco 1921 router running 15.7(3)M2 that is consistently dropping certain packets but not others for reasons that are not clear. As an example, a DNS response for stltoday.com (from any server) gets completely dropped (no return packet on Wireshark), but the response for amd.com always gets through. Both response packets are under 200 bytes and thus vastly smaller than the MTU. The problem also affects rsync, but it seems not to affect anything else. This is not a hardware fluke. This router passes hardware tests, and the problem started on the previous router (an 891W). This is also not an upstream connectivity issue. This router and other devices connected directly to the modem are able to complete the DNS requests (and so the work-around right now is for the router to work as a pass-through DNS server). I can't imagine this being anything other than a bug, but I'm eager to get it solved either way.
! Last configuration change at 18:34:02 UTC Wed Oct 2 2019 by cisco
version 15.7
hostname ht312-router
boot-start-marker
boot system usbflash0 c1900-universalk9-mz.SPA.157-3.M2.bin
boot-end-marker
enable secret 5 $4$MExE$REDACTED/REDACTED/XXX/
no aaa new-model
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.0.1 192.168.0.63
ip dhcp excluded-address 192.168.2.1 192.168.2.16
ip dhcp excluded-address 192.168.4.1 192.168.4.15
ip dhcp pool cvo-pool
 import all
 network 10.10.10.0 255.255.255.248
 default-router 10.10.10.1
 lease 0 2
ip dhcp pool dhcp0
 network 192.168.0.0 255.255.255.0
 default-router 192.168.0.1
 dns-server 192.168.0.1 208.67.222.123 208.67.220.123 8.8.8.8
 accounting default
ip dhcp pool dhcp2
 network 192.168.2.0 255.255.255.0
 default-router 192.168.2.1
 dns-server 192.168.2.1 8.8.8.8 8.8.4.4
 option 43 hex f104.c0a8.020e
 accounting default
ip dhcp pool dhcp12
 network 192.168.4.0 255.255.255.0
 accounting default
ip domain name local
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1921/K9 sn XXXXXXXXXXX
username cisco privilege 15 secret 5 $4$JE78$REDACTED0REDACTED0XXX.
redundancy
bridge irb
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
! Trunk to main switch.
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.1
 encapsulation dot1Q 1 native
 bridge-group 1
interface GigabitEthernet0/0.2
 encapsulation dot1Q 10
 bridge-group 2
interface GigabitEthernet0/0.12
 encapsulation dot1Q 12
 bridge-group 12
! Uplink to modem.
interface GigabitEthernet0/1
 ip address dhcp
 ip access-group 101 in
 no ip redirects
 no ip proxy-arp
 ip flow ingress
 ip nat enable
 ip virtual-reassembly in
 duplex auto
 speed auto
! Main internal network.
interface BVI1
 ip address 192.168.0.1 255.255.255.0
 ip access-group 100 in
 no ip redirects
 ip nat enable
! Wireless infrastructure network.
interface BVI2
 ip address 192.168.2.1 255.255.255.0
 no ip redirects
 ip nat enable
! Guest network.
interface BVI12
 ip address 192.168.4.1 255.255.255.0
 no ip redirects
 ip nat enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat source list 1 interface GigabitEthernet0/1 overload
ip nat source list 65 interface GigabitEthernet0/1 overload
ip nat source list 101 pool globalnet overload
ip nat source static tcp 192.168.0.35 22 interface GigabitEthernet0/1 2930
ip nat source static tcp 192.168.0.35 3030 interface GigabitEthernet0/1 3030
logging history size 128
access-list 1 permit 10.10.10.0 0.0.0.7
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 65 permit 192.0.0.0 0.255.255.255
access-list 72 permit 192.0.0.0 0.255.255.255
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 permit ip any any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
bridge 12 protocol ieee
bridge 12 route ip
no vstack
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 access-class 23 in
 privilege level 15
 login local
 transport input telnet ssh
scheduler allocate 20000 1000
event manager environment _internet_route_established_phrase LINK-3-UPDOWN
event manager directory user policy "usbflash0:/"
! Work-around for the NVI rule-dropping bug.
event manager policy fix_nvi.tcl
end
looking at your configuration, the first thing that looks odd is that you turned off CEF, which means everything gets process switched (which usually slows down everything). Try to enable process switching (ip cef).
I have made some changes (marked in bold) to your configuration, as a lot of things are reddundant:
version 15.7
boot-start-marker
boot-end-marker
no aaa new-model
import all
lease 0 2
ip dhcp pool dhcp0
dns-server 8.8.8.8 208.67.222.123 208.67.220.123 192.168.0.1
accounting default
ip dhcp pool dhcp2
dns-server 8.8.8.8 8.8.4.4 192.168.2.1
accounting default
ip dhcp pool dhcp12
accounting default
--> ip cef
no ipv6 cef
cts logging verbose
redundancy
bridge irb
no ip address
shutdown
no ip address
duplex auto
speed auto
bridge-group 1
bridge-group 2
bridge-group 12
! Uplink to modem.
ip address dhcp
--> no ip access-group 101 in
no ip redirects
no ip proxy-arp
ip flow ingress
ip nat enable
duplex auto
speed auto
interface BVI1
--> no ip access-group 100 in
no ip redirects
ip nat enable
interface BVI2
no ip redirects
ip nat enable
! Guest network.
interface BVI12
no ip redirects
ip nat enable
no ip http server
ip dns server
--> no ip nat source list 65 interface GigabitEthernet0/1 overload
--> no ip nat source list 101 pool globalnet overload
--> access-list 1 permit 192.168.0.0 0.0.255.255
--> no access-list 65 permit 192.0.0.0 0.255.255.255
--> no access-list 72 permit 192.0.0.0 0.255.255.255
--> no access-list 100 deny ip host 255.255.255.255 any
--> no access-list 100 permit ip any any
control-plane
bridge 1 route ip
bridge 2 route ip
bridge 12 route ip
no vstack
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
end
5 Replies 5
Deepak Kumar
As you assigned the primary DNS server as your Local Router. Can you change primary DNS server to 8.8.8.8 and test it the same?
ip dhcp pool dhcp0
 no dns-server 192.168.0.1 208.67.222.123 208.67.220.123 8.8.8.8
dns-server 8.8.8.8 208.67.222.123 208.67.220.123 192.168.0.1 accounting default
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi, Deepak.
Per my original message, the problem is that the router is not passing some DNS packets between the NAT outside and inside, so setting 8.8.8.8 as the first DNS server for internal DHCP clients would cause them to be unable to access some sites.
version 15.7
boot-start-marker
boot-end-marker
no aaa new-model
import all
lease 0 2
ip dhcp pool dhcp0
accounting default
ip dhcp pool dhcp2
accounting default
ip dhcp pool dhcp12
accounting default
--> ip cef
no ipv6 cef
cts logging verbose
redundancy
bridge irb
no ip address
shutdown
no ip address
duplex auto
speed auto
bridge-group 1
bridge-group 2
bridge-group 12
! Uplink to modem.
ip address dhcp
no ip redirects
no ip proxy-arp
ip flow ingress
ip nat enable
duplex auto
speed auto
interface BVI1
no ip redirects
ip nat enable
interface BVI2
no ip redirects
ip nat enable
! Guest network.
interface BVI12
no ip redirects
ip nat enable
no ip http server
ip dns server
control-plane
bridge 1 route ip
bridge 2 route ip
bridge 12 route ip
no vstack
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
end
Thanks, Georg!
I applied a few changes at a time to see the critical point, if any. DNS packets started transiting properly after the second of these steps below, with the others included since they seem closely related.
rsync is still not working, so I guess that that's a separate issue, maybe MTU instead of NAT.
Hi, Georg.
Upon further testing, I do not think that the remaining problem (just with rsync so far as I can tell) is an MTU issue after all. Could you take another look at my patched configuration in the new issue for other possible sources of erratic behavior?
