Odd Traceroute Response !
danyell27
SERVER: Traceroute to 208.0.Y.X (208.0.Y.X):
1 198.162.K.L (198.162.K.L) 2 ms 1 ms 1 ms
2 198.162.S.T (198.162.S.T) 3 ms 4 ms 5 ms
3 192.168.170.113 (192.168.170.113) 5 ms 3 ms 3 ms
4 192.168.170.9 (192.168.170.9) 147 ms 149 ms *
5 192.168.170.9 (192.168.170.9) 149 ms 162 ms *
6 192.168.170.9 (192.168.170.9) 152 ms 153 ms *
7 192.168.170.9 (192.168.170.9) 146 ms 151 ms *
8 192.168.170.9 (192.168.170.9) 150 ms 150 ms *
9 192.168.170.9 (192.168.170.9) 149 ms 151 ms *
10 192.168.170.9 (192.168.170.9) 150 ms 152 ms *
11 192.168.170.9 (192.168.170.9) 151 ms 153 ms *
12 192.168.170.9 (192.168.170.9) 147 ms 145 ms *
13 192.168.170.9 (192.168.170.9) 164 ms 155 ms *
14 192.168.170.9 (192.168.170.9) 164 ms 186 ms *
15 192.168.170.9 (192.168.170.9) 154 ms 148 ms *
16 192.168.170.9 (192.168.170.9) 146 ms 153 ms *
17 192.168.170.9 (192.168.170.9) 147 ms 155 ms *
18 192.168.170.9 (192.168.170.9) 150 ms 150 ms *
19 192.168.170.9 (192.168.170.9) 155 ms 146 ms *
20 * * 198.162.X.X (198.162.X.X) 3 ms
21 198.162.X.X (198.162.X.X) 3 ms 3 ms *
22 198.162.X.X (198.162.X.X) 3 ms 3 ms *
23 198.162.X.X (198.162.X.X) 5 ms 3 ms *
24 198.162.X.X (198.162.X.X) 8 ms 3 ms *
25 198.162.X.X (198.162.X.X) 3 ms 3 ms *
26 198.162.X.X (198.162.X.X) 3 ms 3 ms *
27 198.162.X.X (198.162.X.X) 3 ms 3 ms *
28 198.162.X.X (198.162.X.X) 3 ms 3 ms *
29 198.162.X.X (198.162.X.X) 4 ms 3 ms *
30 198.162.X.X (198.162.X.X) 3 ms 6 ms *
hop limit reached:
Can someone help decipher this odd behaviour of the traceroute command as shown in the output above. For some reason when it hits the 192.168.170 network, i get multiple hop counts on the same router.
Thanks in advance .
scottmac
Level 10
Level 10
What does a PING do to the same address? If you get "TTL Timeout", then you have a router loop.
Good Luck
Scott
Thanks for the response Scott, A ping actually goes through.
regards
Danyell
vladrac-ccna
Level 5
Level 5
Not sure this is what is happening in this case. But I've seen this behaviour when 1 of the hops (or the repeating one) is a firewall.
As for security reasons it wont sent the response from the inside routers back to you, it replied as if it was the firewall itself.
Usually you can check TTL values to make sure they are different (meaning your packets travelled through another hop).
Hope this help a bit,
if it does, please rate this post.
Vlad
