OER - Optimized Edge Routing
Anybody implemented before OER ? Can anybody sendme an example?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I have, but it was at a former job, and I don't use it in my current job (nor do I have saved configs from my prior job).
BTW, PfR is basically the V2 version of OER.  Unless you're using some old IOS, you'll probably use PfR, which does have some new features.
I liked it, but you'll probably want, or should, change some timers (basically to get the analysis time down).  It also has a couple of "gotchas" (at least it did for me).  Two I ran into, first, if doing active analysis, you got to be careful you don't overload your device with OER generated SLA tests.  Second, if working BGP, you need to send communities to BGP peer for BGP to hold the no export OER generated routes.
Depending on how you plan to use it, you may also want to rethink how you process routes.  For example, I found OER managing a pair of Internet (edge) routers, using defaults, better than accepting even the complete Internet route table.
Thanks for your reply Joseph !
