OIR in 3845
justin.donoghue
hi
I know online insertion and removal is supported on the 3845 router but my question is does this cover placing a network module into a free slot on the router while it is powered up as opposed to swapping out an existing network module?
aghaznavi
Level 5
Level 5
The Cisco 3845 router supports OIR with similar modules only. If you remove a network module, along with any installed WAN or voice interface cards, install another module and card combination exactly like it.
The Cisco 3825 router does not support OIR of network modules. To avoid damaging the module, you must turn off electrical power and disconnect network cables before you insert the module into a router slot.
For more details on 3800 series cards and Modules follow the url,
http://www.cisco.com/en/US/products/ps5855/prod_module_install_config_guide09186a00802c4856.html
