on a cisco nexus 9000 what are mac moves
2021 Dec 6 10:43:28 tor01.swu.library.tx %L2FM-4-L2FM_MAC_MOVE2: Mac 204c.034d.13a3 in vlan 350 has moved from Po1 to Po7 (message repeated 1 time)
this is constantly happening on this switch.
Seb Rupik
Hi there,
The message is generated when a dynamically learnt MAC address moves between ports in the same VLAN.
This is common to see with wireless clients roaming, or vmotion taking place. Do you know what device the MAC 204c.034d.13a3 belongs to and what VLAN 350 is used for?
cheers,
Seb.
Thank you for the response so when I do a show mac add on the nexus it shows up on the vPC Peer-Link
Which when I dig a little more into the vPC I see one of our Pochannels for the VPC is down, I just found this out.
46 Po46 down* failed vpc port channel -
mis-config due to vpc
links in the 2
switches connected to
different partners
Do you have any network diagram showing how it looks your connection?
BB
